nissan sentra spec-v rims
Old Jul 22, 2004 | 03:01 PM
4DRmafia's Avatar
Default nissan sentra spec-v rims
will they fit on the ef hatch,sedan even if they are 4 lug or not bec 1 time i was reading a post from some where esle and i saw an accord alloy rims fited on the nissan 240sx or soemthing so i was thinking if that sentra rim will fit on our ef stud pattern...
Old Jul 22, 2004 | 03:28 PM
4DRmafia's Avatar
Anyone ?...
Old Jul 22, 2004 | 03:51 PM
jdl3000's Avatar
Default Re: nissan sentra spec-v rims (SkipMic2006)
check the bolt pattern
ef civic is 4 X 100
Old Jul 22, 2004 | 07:26 PM
4DRmafia's Avatar
yea i know but i just saw once on the 240 with the 94-97 accord alloy rims and i was thinking if sentra will fit or not
Old Jul 22, 2004 | 07:40 PM
HondaKPX's Avatar
Default Re: (SkipMic2006)
call up a tire place and ask what the bolt pattern is for a sentra and if its 4 x 100 then the bolt patter will fit. dont know about the offset though
Old Jul 22, 2004 | 07:50 PM
4DRmafia's Avatar
are they 16 or something ?
Old Jul 22, 2004 | 08:54 PM
EL Vap133's Avatar
The Accord has a different bolt pattern than the Civic.
Old Jul 22, 2004 | 09:05 PM
4DRmafia's Avatar
what year the accord u talking abt ?
Old Jul 23, 2004 | 01:47 AM
mikerbike's Avatar
He's talking about any accord made after 89. 240 sx's use the 4X113.4 like the accords. You should just clip a tape measure to your belt and keep it there until you see a parked Spec-V, then run up and measure the bolt pattern. It would take longer than figuring it out the easy way, but it would be much funner.
Old Jul 23, 2004 | 04:47 AM
dfwaltima's Avatar
They will not fit, the SpecV rims are 4X114.3 and they are 17's that came in the 02-03 models..
Old Jul 23, 2004 | 06:24 AM
EL Vap133's Avatar
Default Re: (mikerbike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikerbike &raquo;</TD></TR><TR><TD CLASS="quote">He's talking about any accord made after 89. 240 sx's use the 4X113.4 like the accords. You should just clip a tape measure to your belt and keep it there until you see a parked Spec-V, then run up and measure the bolt pattern. It would take longer than figuring it out the easy way, but it would be much funner.</TD></TR></TABLE>
Exactly, 90+ Accord ha s a different lug pattern.
Sherif
Apr 28, 2017 09:39 AM
SkaiWu
Jul 28, 2008 10:04 PM
Desi2486
Jun 9, 2006 01:18 PM
blackwidowed_accord
Apr 1, 2004 12:30 AM
civic7gen
Nov 26, 2002 05:07 AM
