Paint Question.
Old Jul 22, 2004 | 01:20 PM
mongoliandonuts's Avatar
Default Paint Question.
I need too touch up a few spots on my Red Del sol 1994 si, and I was wondering you guys have any knowledge about how to paint a car at home and make it pretty, what can i buy at the store that matches well and how many clear coats ETC. if you have any ideas let e know thanks a bunch.
Old Jul 22, 2004 | 01:32 PM
Default Re: Paint Question. (mongoliandonuts)
are honda a enamel or laqcuer?
Old Jul 22, 2004 | 02:29 PM
AWDxBOOST's Avatar
just to tell u it wont turn out pretty if its ur first attempt
best bet is to buy some touch up paint from honda, gently sand with fine grit paper and apply a couple even coats and seal with some clear coat
that is if ur just talkin about lil touch up spots
if u need to paint a large portion, find a paint gun...best and imo easiest way to get good results
same idea, sand down as much as needed with fine grit, unless ur goin fairly deep, which in that case u can use bigger grit and work ur way to fine as u get closer to the desired depth
then tape ur car off and have at it with smooth even sprays, and let dry and go over with clear coat and ur good
Old Jul 22, 2004 | 02:34 PM
egisk09
Guest
Posts: n/a
i go to school for painting n body work. dont do it ur self..not worth it. best advice go to maaco..very cheap
Old Jul 22, 2004 | 03:14 PM
spyderracing's Avatar
Default Re: (egisk09)
isnt maaco shitty?
Old Jul 22, 2004 | 07:44 PM
AWDxBOOST's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egisk09 &raquo;</TD></TR><TR><TD CLASS="quote">i go to school for painting n body work. dont do it ur self..not worth it. best advice go to maaco..very cheap</TD></TR></TABLE>
why's this...ive done plenty of stuff thats turned out decent
Old Jul 22, 2004 | 07:58 PM
IVI's Avatar
IVI
Default Re: (spyderracing32)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spyderracing32 &raquo;</TD></TR><TR><TD CLASS="quote">isnt maaco shitty?
theyre basic service is very shitty.. but if you get a high quality job there it should be okay but then its not cheap anymore and they are VERY expensive.
courtney42
Paint and Body
Apr 2, 2009 06:14 AM
g0tgot
Paint and Body
Mar 6, 2009 08:51 PM
firstgenrex
Sep 12, 2003 08:49 PM
COMplex.
May 4, 2003 01:00 AM
Cryptopsy
Mar 26, 2002 08:04 PM
