1 Wire o2 sensor for AFR Gauge?
I dont have an o2 sensor because me ecu doesnt recgonize one, but i need one simply for a AFR gauge, so with that said will a 1 wire o2 bosch o2 sensor suffice?
Yes it will work but one word of warning:
The single wire O2 sensor does not have an internal heater and relies on heat from the exhaust manifold. This type of sensor needs to be placed VERY CLOSE to the exhaust ports, in order to work. (about 12 inches away max)
Hope this helps.
Hope this helps.
Yes a heated sensor will work but you will have to wire 12v supply to the heater on the sensor.
The heated sensor made by NTK is a 4 wire type used in most hondas.
The two WHITE wires are the heater wires
The GREY wire is the sense wire and the BLACK wire is the ground.
Best to wire a relay to switch +12v across the two WHITE wires when the ignition is switched ON.
