lights dimming????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phatch99 »</TD></TR><TR><TD CLASS="quote">what cause lights in the car to dim when foot off gas and brighting up when accelarating?</TD></TR></TABLE>
The very tiny alternator in the engine bay. It's weak. You can remedy this by replacing all your grounds in the engine compartment with 8ga audio wire for less resistance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtyd463 »</TD></TR><TR><TD CLASS="quote">two words
VOLTAGE REGULATOR
VOLTAGE REGULATOR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FWejCOUPE »</TD></TR><TR><TD CLASS="quote">you could have a draw in the system. something could be going bad or have a bad connection thus causing it to use more power. </TD></TR></TABLE>
Every civic I've ever been in has had lights dim / fan slow what have you when idling that went away when on the gas. Some people never noticed it until I pointed it out though. Improve your grounds, and it will remedy, if not take care of the whole problem.
