Suzuki Grand Vitara Pistons. Sohc Zc. 125 Dry Shot HELP
Old Jul 22, 2004 | 10:39 AM
Traction's Avatar
Default Suzuki Grand Vitara Pistons. Sohc Zc. 125 Dry Shot HELP
I was just told to stay away from the Arias pistons I was gonna buy because they said Suzuki grand vitara pistons will fit in my stock zc no problem and can hold high boost. Is this true?
Theyll fit right in? Just buy some new rings and slap them on some d series forged rods no problem?
They will be going on a built d series with a 125 shot so they need to hold up. Any info will be greatly appreciated
THanks
Old Jul 22, 2004 | 10:52 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: Suzuki Grand Vitara Pistons. Sohc Zc. 125 Dry Shot HELP (StealthEF)
Intresting... I've never heard of it being done.
Old Jul 22, 2004 | 11:55 AM
rob42386's Avatar
Default Re: Suzuki Grand Vitara Pistons. Sohc Zc. 125 Dry Shot HELP (LSVTEC 91 Civic)
Yes they fit all D series motors with the 75 bore size, you can also get them oversized too, not sure what size tho?
Been a very hot topic for the last few months!!! The c/r is a mid 8, and is excellent for high boost, ive heard that they boost to 20 lbs, but make sure that your rods, and other stuff can take the high pressure!
Old Jul 22, 2004 | 11:56 AM
rob42386's Avatar
Default Re: Suzuki Grand Vitara Pistons. Sohc Zc. 125 Dry Shot HELP (rob42386)
BTW: a 125 dry shot would be sorta pointless, go with a wet kit to make real power, and its way safer!
Old Jul 22, 2004 | 12:18 PM
Full Race A6's Avatar
Wet is not safe at all. It puddles
Id defientely stay away from wet. If you dont have the money to go direct port then go dry.
Ive seen 2 integras at the track spraying a large dry shot (over 100), just grab some bigger jets from zex.com, I think they still sell them, maybe the ones they make for v8's will work
I was also interested in this piston idea but didnt think I would clear to well.
Ive got an A6 head, milled.040, ferrea retainers, dual titanium springs, 1mm oversized valves, delta 272 cam
Im pretty much decided on Arias 11.5:1 comp pistons and some nitrous
Old Jul 22, 2004 | 05:17 PM
Traction's Avatar
solerizr
Jan 3, 2007 04:41 PM
zcdohcturbo
Apr 7, 2006 04:57 PM
JDM_ZC
Apr 2, 2006 10:15 AM
Traction
Jul 22, 2004 11:10 AM
DOHCtor Boost
May 3, 2004 06:31 PM
