Factory rear disc setup off of a 1991 crx si.
Old Jul 22, 2004 | 10:36 AM
JapJunkie's Avatar
Default Factory rear disc setup off of a 1991 crx si.
yo whats up, Im looking to get rear disc brakes on my 88 hatch, which i already have DA front brakes. I was thinking of getting DA rears also, but a guy is selling his New CRX Si rear disc. Which ones shall i get? Are the DA rear disc rotors the same size as the CRX ones? Also can u upgrade the size of the rotors on the rear disc brakes? Thank you in advance.
Old Jul 22, 2004 | 10:53 AM
crx_88_si's Avatar
they are the same except the teg has a slightly larger bore on the piston in the rear calipers.
Old Jul 22, 2004 | 10:58 AM
Fred.Rodgers's Avatar
Default Re: (crx_88_si)
here is another brake question: can you put the front brakes of a crx on the rear??
cause if i upgrade the brakeing power of the fronts, than i want to upgrade the rears. and yes, i am aware that the rears only provide 30% blah blahblah. 30% of a 2600lbs. car is still 780lbs. times brakeing force which is like a gee and a bit....well, you get my point.
Old Jul 22, 2004 | 10:59 AM
JapJunkie's Avatar
Default Re: (Transptr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Transptr &raquo;</TD></TR><TR><TD CLASS="quote">here is another brake question: can you put the front brakes of a crx on the rear??
cause if i upgrade the brakeing power of the fronts, than i want to upgrade the rears. and yes, i am aware that the rears only provide 30% blah blahblah. 30% of a 2600lbs. car is still 780lbs. times brakeing force which is like a gee and a bit....well, you get my point.</TD></TR></TABLE>
WTF start ur own thread homie
Old Jul 22, 2004 | 11:00 AM
JapJunkie's Avatar
So should i get the CRX si rear disc???
Old Jul 22, 2004 | 11:15 AM
EL Vap133's Avatar
Default Re: (hOnDadiCt)
Whichever ones you want, they're pretty much the same.
91efsikevs
Suspension & Brakes
Dec 1, 2008 11:55 PM
littlebill
10
Jun 11, 2007 04:55 PM
La EF-8
Jul 17, 2006 02:58 AM
classciv
16
Jun 9, 2006 05:21 PM
SPL KID
Apr 26, 2005 03:55 PM
