Violent engine vibration . Help Help Heeellllppppppppp!!!!!
Old Jul 22, 2004 | 10:22 AM
Rocks
Guest
Posts: n/a
Default Violent engine vibration . Help Help Heeellllppppppppp!!!!!
My car has a big vibration issues. So far I have changed my axles and my drivers side motor mount. My DS motor mount snapped in two and I felt some vibration (the same as I feel right now) so I replaced it. Now my problem has given me a big headache. I cant stand driving the car. It vibrates violentley like the motor is about to fall out. I tightend up my DS motor mount because I thought it was lose and that was causing the problem. I checked my drivers side mount and my tranny mount the only one I havent checked is the other mount because I havent got a chance to lift up the car. One question for you guys do you guys believe that if that mount is busted (the one I havent checked) do you believe my engine could shake violentley . Even when I start my car up it jumps back and forth I know this because I asked my brother to start the car and I wa like WTF is wrong with my car.
Old Jul 22, 2004 | 10:39 AM
Deemeetree's Avatar
Electrician
Check your motor and tranny mounts, if necessary, change out with poly inserts.
Old Jul 22, 2004 | 10:53 AM
realblag's Avatar
Default Re: Violent engine vibration . Help Help Heeellllppppppppp!!!!! (Rocks)
If you rev the engine with the car stopped, does it do it or do you have to be moving?
Old Jul 22, 2004 | 10:58 AM
Rocks
Guest
Posts: n/a
Default Re: Violent engine vibration . Help Help Heeellllppppppppp!!!!! (realblag)
it only moves violentley when I start the car. When I pull on the throttle cable it moves about 1 - 1 1/2 inches back it dosent look as violent. But when I start the car that think flops around like crazy.
Old Jul 22, 2004 | 11:16 AM
realblag's Avatar
Have you checked out your rear motor mount? If its torn up or the bolts are not tight, your motor will raise hell.
Old Jul 22, 2004 | 11:41 AM
mikehawkBUiLT's Avatar
yes, its probably your rear motor mount
i had this problem in my crx and my motor would rock. luckily i had a front upper strut bar to prevent my motor from going through my hood. it was the rear motor mount that broke in half cause of hard shifting and a 4 puck clutch on me
Old Jul 22, 2004 | 11:49 AM
menkio's Avatar
Default Re: (EJcoupe)
ohh yea, rear mount, that can cuase some serious vibration
Old Jul 22, 2004 | 12:07 PM
Rocks
Guest
Posts: n/a
Default Re: (DewMota)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DewMota &raquo;</TD></TR><TR><TD CLASS="quote">ohh yea, rear mount, that can cuase some serious vibration</TD></TR></TABLE>
Im having my mechanic look at it today. I have no time for this . I have to take car of my baby . Thanks alot guys.
Old Jul 23, 2004 | 02:29 AM
BlackEg9sd's Avatar
Default Re: (Rocks)
thats how my car was when i swapped in the the LS i forgot to tighten the rear mounts L BAR as i was driving it started to make noises like my pipings were scrapping and my motor was vibrating every time i stepped on it felt like it was gonna drop so i just pulled over and tighten it
Old Jul 23, 2004 | 11:13 AM
Rocks
Guest
Posts: n/a
Default Re: (BlackEg9sd)
I think I found the culprit. I checked the mount and couldnt see any tears or anything BUT.... When I pulled the throttle cable even a bit it looked like that motor mount wasent helping at all. It flexed down alot. My friend has a SI also and called him over to check it out and his did not flex at all it would move a little but not as much as mine.
Old Jul 23, 2004 | 11:17 AM
jdmeg21's Avatar
Its the rear motor mount, I broke mine 3 times, and kept rewelding them till I replaced it. When it broke the motor would jerk foward bad, and when driving, I would let off the gas and could hear a loud clank noise. Just buy some good hasport mounts
Old Jul 23, 2004 | 11:19 AM
Rocks
Guest
Posts: n/a
Default Re: Violent engine vibration . Help Help Heeellllppppppppp!!!!! (jdmeg21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmeg21 &raquo;</TD></TR><TR><TD CLASS="quote">Its the rear motor mount, I broke mine 3 times, and kept rewelding them till I replaced it. When it broke the motor would jerk foward bad, and when driving, I would let off the gas and could hear a loud clank noise. Just buy some good hasport mounts</TD></TR></TABLE>
I found the whole mount kit brand new for 330
shady8277
Jan 7, 2013 07:00 AM
airikkCRX
Jul 12, 2008 05:24 AM
Backk InTheDA
Aug 3, 2005 11:57 AM
LiL accORd RideR
Jan 21, 2005 03:15 PM
