Hayame full coilover kit....Good or Bad?
I was lookin at a Tien coilover but I dont know if I want to spend that much so I was lookin and I found the Hayame full coilover on clearance, but I dont know anything about it. Any info or opinion from someone that has used this coilover?
GREAT product.. my friend just got it on his EK and it has both adjustable ride height and adjustable shock lenght.. and they are pretty cheap around 650ish for the full set... they use tokico shocks on their products and i would compare them to the omni power.. hes had no problems whatsoever and the ride is great. he has a pretty big drop to where his front wheels are just about tucked and his backs are a tad higher but not much
tein is one of the best companies in my opinion but i really want the hayames for my car and i have the AGX and Ground control setup... so i like them better than that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSR »</TD></TR><TR><TD CLASS="quote">As good as Tien or close? Cuz as far as I kno those are pretty close to the best under 1500.</TD></TR></TABLE>
Teins aren't the best out there. There's plenty of good coilovers that you can mate to good struts/shocks that are well below $1,500. Have you looked into OmniPower Full Coilovers? Full threaded body, complete assembly with shocks, ready to bolt in for $700. http://www.omnipowerusa.com Great stock rates and I believe it's the same guy who builds or created the Skunk2 coilover system, so you know it's top knotch.
There's some threads on Omni's aswell.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM EJ1 95 »</TD></TR><TR><TD CLASS="quote">the omnipower if im corrrect are the exact same things as the hayame... </TD></TR></TABLE>
and the (depending on the model) teins are better than both .
you say you have kyb's and GC's? then id just get some koni's and call it a day
Just want to correc this post in case someone comes across it in a search...
Omnipower's current coilovers are not the same as Hayame's.
