car has no power
Old Jul 22, 2004 | 07:29 AM
JSPECEX's Avatar
Default car has no power
i just put in a crvtec and it will drive but makes no power and has a check engine light. i didn't install the knock sensor but i thought that it would only cause no vtec if anything. i also installed a vtec controller at the same time and if i un plug it the car will run but wont move. it is an older vtec controller so i am pretty sure you don't have to set wot on it. i can't figure it out. i thought maybe timing but the idle is right at a steady 800 -900 rpm. please guys i need to figure this out it is my only car
Old Jul 22, 2004 | 08:09 PM
JSPECEX's Avatar
Default Re: car has no power (JSPECEX)
bump
Old Jul 23, 2004 | 08:30 AM
93H22ACX's Avatar
read the CEL and post it and do a compression test..
a disconnected knock sensor will still engage vtec.
maybe you installed the vtec controller wrong...
95b16civic
Mar 16, 2010 09:04 PM
mmcsiggi
Feb 19, 2010 04:07 PM
Laojoeturbo
34
Jun 24, 2009 08:47 AM
h22ek9forme
Nov 12, 2007 10:48 AM
CrisEK
Jun 2, 2005 11:46 AM
