Which axle to use on an EF9 Sir?
I am about to purchase a 1990 EF9 SiR (right hand drive).
The drivers side CV axle needs to be replaced. I need to know what kind of
axle I need to ask for when ordering through a parts store. Thanks.
Sounds like a second Gen Integra axle would work nicely if, indeed, it is a b16a. That is what I would try first. Where are you getting the car from?
hatch box ment 90-93. But if you have a y1 tranny and int shaft you need 89 integra outer joint/shaft, and 90-93 teg inner joint(I believe). Basically you have to make a sir joint. Call http://www.raxles.com, tell them what kind of trany you have, and the car and they will make it for you.
Ryan
Ryan
whoa. lol yea 90-93 teggie axles
if you have a y1 tranny , all you do is switch the intermediate shaft for a 90-93 LS one and you can run the 90 -93 axles with that .
ThaEfSwap
Mar 24, 2014 04:09 PM
aojtin
Mar 6, 2009 12:26 PM
shiithook
May 28, 2002 12:02 PM
