Back from the Track - b16 in EG
Old Jul 22, 2004 | 07:09 AM
Jahtoot84's Avatar
Default Back from the Track - b16 in EG
Well im quite happy with how my car is running. The first time I went to the track, ran on steelies and did a 15.3 with horrible 60ft times.
After purchasing some Azenis I went back to the track again to try my luck
My setup is a JDM b16 from hmotorsonline in a 95 CX hatchback.
Things I changed while doing the swap, was timing belt, ACT street disc clutch kit, water pump, spark plugs/wires and a Fidanza Flywheel (spelled wrong prolly).
Took the car to the track with full interior, including the spare tire and jack.
No mods done other than stated, I just put a cheapo filter my friend gave me on the stock intake tube.(too broke after swap, buying a short ram intake soon tho).
Oh yea, i got a custom 2.5 crush bent piping with a resonator opened up to a 3inch N1 muffler. Surprisingly its not that loud until I hit "VTEC"H" YO" then all hell breaks loose
Anyways, here are my crappy times...( Track : Orlando Speedway )
R/T 60' 330 1/8 MPH 1000 1/4 MPH
1.082.......2.346........6.262.......9.558......75 .28....12.415.......14.852.....91.85
1.015.......2.291.......6.202.......9.499.......74 .78.....12.364.......14.805.....91.67
All in all im happy, I was launching at 5,500rpms and slipping the clutch. Tried alot of other methods to lower my 60ft times, but launchin that high and slippin the clutch seemed to yield the best times that night. Im not an experienced drag racer so just looking for some hints.....
Thanks for reading this far if ya made it, peace....
Old Jul 22, 2004 | 09:54 AM
DC5ITR329's Avatar
Default Re: Back from the Track - b16 in EG (Jahtoot84)
try different RPMs and lower your tire pressure.
Old Jul 22, 2004 | 10:08 AM
Hybrid96EK's Avatar
You sure you are happy with those times? I mean, 91mph is one hell of a low trap for a B16 in an EG hatch. I was able to hit those traps in my 99 Si with only intake and header. Your 60 foots aren't that bad either... I don't know what is up, but I personally think 91mph is a bit of a low trap for that setup.
Old Jul 22, 2004 | 10:13 AM
Jahtoot84's Avatar
Default Re: Back from the Track - b16 in EG (Hybrid93Eg)
yea the trap seems low? I dunno. Lots were telling me 14.8 is not a bad time for the 60fts im pulling. Think somethings up with my engine?
Old Jul 22, 2004 | 10:17 AM
Declectic's Avatar
i think the way your setup is now, you could hit mid 14s if you worked at it
i got a 00Si and i've got the same 60fts as you (2.2's) but i do have LSD
next time just take out the spare and the jack though
Old Jul 22, 2004 | 10:18 AM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jahtoot84 &raquo;</TD></TR><TR><TD CLASS="quote">yea the trap seems low? I dunno. Lots were telling me 14.8 is not a bad time for the 60fts im pulling. Think somethings up with my engine? </TD></TR></TABLE>
Yeah, 91mph is a pretty weak trap for a 160hp hatch. I would think somewhere around 95 would be more like where you should be trapping. I can't really compare your traps to mine as my engine is somewhat built and its not a B16... But I am trapping at 98mph in a 93 CX. My friend had a B16 in an EF hatch with similar mods to yours and he was pulling consistant 95mph traps. Stick your car on the dyno and see if it pulls low numbers. You should be around 145 to the from wheels.
Old Jul 22, 2004 | 10:19 AM
Hybrid96EK's Avatar
Default Re: Back from the Track - b16 in EG (SeanJohn1802)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SeanJohn1802 &raquo;</TD></TR><TR><TD CLASS="quote">i think the way your setup is now, you could hit mid 14s if you worked at it
next time just take out the spare and the jack though</TD></TR></TABLE>
I don't know. I can't see mid 14's with those traps. Just doesn't sound like its going to happen.
Old Jul 22, 2004 | 11:13 AM
1.8LHatch's Avatar
my buddy's cx w/b18b was running 15.0x w/ 93+trap speeds
Old Jul 22, 2004 | 11:26 AM
dxhatch93's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah, 91mph is a pretty weak trap for a 160hp hatch. </TD></TR></TABLE>
its a 170hp hatch.
Old Jul 22, 2004 | 11:42 AM
92CivicSiR2's Avatar
Default Re: Back from the Track - b16 in EG (dxhatch93)
I also have a '92 Civic VX with a jdm B16 in it. The mods i have are DC Sports 4-1 header, cheap intake tube and filter, no cat, Thermal RD Snyper Cat-Back, gutted full interior except dash and seats, skunk 2 short shifter, and eibach pro kit with kyb struts. I no i no i should take it to the track one of these days but havent had time to but what would be some estimates on times. Thanks i just saw this thread and think i could run maybe a bit faster times.
Old Jul 22, 2004 | 12:03 PM
k20GSR's Avatar
Default Re: Back from the Track - b16 in EG (92CivicSiR2)
My 93w/ jdm b16, short ram, act clutch and 4-1 header went 14.3 on street tires, launching at 5500. So you should be doing the same times but then again my buddy was running 14.7s consistently with the same setup and when i drove his car I brought the time down to mine. I was trapping at 96 to 98 with solid 1.9 to 2.1 60 fts.
Old Jul 22, 2004 | 01:21 PM
Jimmy's Avatar
Global Moderator
If i were you i would invest in a nice catback with 2.5 exhaust piping instead if a 3inch muffler..sounds kinda big for n/a
Old Jul 22, 2004 | 01:38 PM
pburke23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dxhatch93 &raquo;</TD></TR><TR><TD CLASS="quote">
its a 170hp hatch.</TD></TR></TABLE>
you sure? He didnt say whether it was a b16a or a b16a2, the b16a has 160hp...the a2 is the one with 170...
Old Jul 22, 2004 | 01:55 PM
HATCHingMN's Avatar
Default Re: Back from the Track - b16 in EG (pburke23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pburke23 &raquo;</TD></TR><TR><TD CLASS="quote">
you sure? He didnt say whether it was a b16a or a b16a2, the b16a has 160hp...the a2 is the one with 170...</TD></TR></TABLE>
no....no...
the b16a2 came with delsol and 99-00 Si put out 160hp
there is no jdm b16a2 only US.
jdm b16a SirII puts out 170hp
Old Jul 22, 2004 | 08:07 PM
BlueSiRII's Avatar
My friend had a 93 CX, w/ an all stock USDM GSR swap, gutted interior and runnin the 13" CX rims he ran a 13.9. Then he wrecked the thing before he even got any mods done to it.
My heavy *** 93 Si w/ JDM b16 w/ factory LSD, ITR intake, DC 4-1, test pipe, Greedy mid pipe, short ram intake, full interior ran a 14.3 but I can not drive!!!!
Old Jul 22, 2004 | 08:23 PM
JDMlyfestyle's Avatar
my b16 is hittin consistant 13.6 w bolt ons and stock block on azenis
Old Jul 22, 2004 | 08:47 PM
McNizzle's Avatar
Default Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">my b16 is hittin consistant 13.6 w bolt ons and stock block on azenis</TD></TR></TABLE>
wtf? maybe i should ditch my b18c for a b16
Old Jul 22, 2004 | 09:05 PM
Default Re: (B18cEG8)
Nice times, i kinda hate going to the track cuz u have to wait for the drag cars and ****.
Old Jul 22, 2004 | 10:36 PM
EG6 SiR's Avatar
Default Re: (92CivicSiR2)
Compared to my setup thats good! I have a 93' Si w/JDM B16 I/H/E and 01'Type R cams with valve springs and the best I pulled was a 9.8 with a trap speed of 74mph. This was in a 1/8 mile track at Irwindale. My 60' times were mostly between 2.3-2.4 yeah I know but I was on some freakin' yokahama AVS ES 100s and I wasnt gripping for ****! Wheel hop all through first. I was launching at 5 grand and feathering the clutch but it wasnt working. I will be picking up some azenis and going back again. Man was I dissapointed!
EDIT: oh yeah, I am running an LS dizzy that didnt fit so I had to cut off one of the legs to fit, so my ignition timing is set at like 7 degrees advanced instead of the 15 degrees its supposed to be, because thats as far as it will go. You think that affected my times?
Old Jul 22, 2004 | 10:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18cEG8 &raquo;</TD></TR><TR><TD CLASS="quote">
wtf? maybe i should ditch my b18c for a b16 </TD></TR></TABLE>
Lol if u got a JDM B18 C type R motor ill be glad to trade you because im bout to upgrade to the R motor. hopefully i could see 12's with that
Rob!
75
Jul 8, 2004 05:49 PM
ViperRedCRX
14
Apr 24, 2003 06:30 AM
Soled Out
Apr 23, 2003 09:03 PM
Seye
17
Apr 5, 2003 12:57 PM
FASTEG
49
Apr 3, 2003 09:33 AM
