Del Sol seat brackets - same as Civic?
Old Jul 22, 2004 | 06:11 AM
RusBear's Avatar
Default Del Sol seat brackets - same as Civic?
Hey, quick question: would '92-on Civic seat brackets fit a '93 del Sol?
Old Jul 22, 2004 | 06:36 AM
Slopoke's Avatar
Default Re: Del Sol seat brackets - same as Civic? (RusBear)
No.
My friend recenty put del sol seats in his civic and the del sol rails would not work.
He had to use is civic rails.
Old Jul 22, 2004 | 07:52 AM
RusBear's Avatar
Default Re: Del Sol seat brackets - same as Civic? (Slopoke)
Do you mean that the bolt pattern (i.e., the spots where you bolt the rail/bracket assembly to the body of the car) is different? The rails came with the aftermarket seat that I bought, I'm just looking for a bracket now. If the bracket cannot be bolted onto the body, I will enter a world of pain
Old Jul 22, 2004 | 08:31 AM
Daniel's Avatar
They may bolt to the seat but probably not to the floorboard of the del Sol. That's why when people like me and others put del Sol seats into our Civics, we have to put the Civic rails onto the del Sol seats. That way they'll bolt to the floor.
Old Jul 22, 2004 | 08:43 AM
Grimm's Avatar
stock rails form your civic seats will bolt to the del sol seat (you will not use all three of the locations only 2)
Please search this topic has been covered before.... And if you just took the time too look at the parts you would beable to do this without any questions, it's a straight forward install...
Old Jul 22, 2004 | 09:05 AM
RusBear's Avatar
Default Re: Del Sol seat brackets - same as Civic? (Grimm)
Uhhh... I have a feeling I'm being misunderstood.
I cannot use OEM rails, I have to use the rails that come with the aftermarket seat. The stock rails and brackets are combined into one assembly; I, however, will have to buy a bracket to attach to the floor, onto which I will bolt the rails that came with the seat. If I could simply use my old rails, I would have done that already.
Now, Daniel answered my question, although he did not sound 100% certain. I guess I can rephrase my query this way: if I were to unbolt a del Sol seat from the floor and move it into a '92 Civic, the bolt holes will not match up. Correct?
Old Jul 22, 2004 | 09:27 AM
Grimm's Avatar
NO they don't match...
Come on now...
If you had a bit of common sense you would see that if you can't use a Del Sol braket(slider) in a civic. Then the reverse is the same... A civic bracket(slider) will not bolt into a Del Sol.
Old Jul 22, 2004 | 09:43 AM
RusBear's Avatar
Grimm, I drive a del Sol. I do not have access to a Civic, but most parts that I can find online are for Civics. That's the only reason I asked. Obviously the reverse of two facts in this case is true, but Daniel didn't sound positive in his reply.
Thanks for the answer that I was looking for, though!
Old Jul 22, 2004 | 09:46 AM
silverEH2's Avatar
i just put del sol seats in a 95 honda civic yesterday, i got all 4 bolts in and i used the stock rails ..you guys should be creative instead of changing the rails
Old Jul 22, 2004 | 10:21 AM
RusBear's Avatar
Default Re: Del Sol seat brackets - same as Civic? (silverEH2)
OK, silverEH2, so you're saying that the floor bolt pattern is the same? Or did you modify the mounting points?
Old Jul 22, 2004 | 11:16 AM
Daniel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RusBear &raquo;</TD></TR><TR><TD CLASS="quote">Now, Daniel answered my question, although he did not sound 100% certain. I guess I can rephrase my query this way: if I were to unbolt a del Sol seat from the floor and move it into a '92 Civic, the bolt holes will not match up. Correct?</TD></TR></TABLE>
Yeah, I was only like 90% sure. Good job on picking that up! Anyway, I see what you're saying now. You have an aftermarket seat that already comes with rails and sliders. Now you just need the "frames" that will connect to all that **** and bolt everything to the floor. If you can get creative then I suppose you could use parts from a Civic. However, do you have access to a junkyard or pick-and-pull? They might have a del Sol hidden away somewhere that you can take apart for the stuff you need.
Old Jul 22, 2004 | 12:03 PM
silverEH2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RusBear &raquo;</TD></TR><TR><TD CLASS="quote">OK, silverEH2, so you're saying that the floor bolt pattern is the same? Or did you modify the mounting points?</TD></TR></TABLE>
the mounting points are not EXACTLY the same but you can flex the rails a bit to bolt up perfectly, i had to do this when i put 99-00 SI seats in as well, i used the stock SI rails in the EG coupe..what im saying is it will work if the rails are simular
Old Jul 23, 2004 | 07:57 AM
RusBear's Avatar
Eh, sucks, can't post more than five times in 24hrs, so I couldn't respond.
Unfortunately, there is (virtually) no way to do anything with the stock del Sol brackets/rails - that stuff is welded together pretty well. I was thinking of going to a junkyard to do the measurement, but I decided to risk it and order Civic brackets from prosportonline.com. We'll see what happens - if I can't get them to fit, I can always use them as a picture frame or something
Thanks for the help!
Old Jul 23, 2004 | 09:04 AM
JapJunkie's Avatar
Nope doesnt work.
Old Jul 23, 2004 | 09:36 AM
pbomers's Avatar
Default Re: Del Sol seat brackets - same as Civic? (hOnDadiCt)
They are different and will not bolt up. You might be able to "make it work," but i wouldn't take that kind of chance with your safety. It's worth the extra time to bolt the del sol cushions to the civic rails and be done with it.
The last thing anybody wants is to have a friend get seriously hurt and die in a car crash because they didn't take the time to bolt the seats in the correct way.
The hassle of switching the cushions/rails over is worth the safety in my opinion.
-P
Old Jul 23, 2004 | 09:42 AM
Hybrid CRX's Avatar
New User
you guys are funny, have you guys actually done it? well i just put some in my eg hatch with NO PROBLEM! the del sol seats and rails fit in there like a beauty!
Old Jul 23, 2004 | 11:27 AM
Grimm's Avatar
Default Re: (Hybrid CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid CRX &raquo;</TD></TR><TR><TD CLASS="quote">you guys are funny, have you guys actually done it? well i just put some in my eg hatch with NO PROBLEM! the del sol seats and rails fit in there like a beauty! </TD></TR></TABLE>
aaahahaha you need to read the posts before you answer...
Oh and I have del sols in my 96 coupe... I had to swap the del sol rails for civic ones...
Old Jul 23, 2004 | 12:22 PM
Daniel's Avatar
Default Re: (Grimm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grimm &raquo;</TD></TR><TR><TD CLASS="quote">
Oh and I have del sols in my 96 coupe... I had to swap the del sol rails for civic ones... </TD></TR></TABLE>
Same here. I speak from experience. If I don't know firsthand then I'll say so. I have del Sol seats (thx Katman!) in my '97 sedan. Don't believe me? Visit my webpage.
Old Jul 23, 2004 | 01:05 PM
RusBear's Avatar
Default Re: (Daniel)
TinyCRX, I hear ya: don't want to risk the chance of the brackets getting ripped out in a crash. Unfortunately, there's simply no way to use the stock brackets/sliders/anything with the seats that I got. Well, other than putting the new seat on top of my old seat and duct-taping the hell out of the two
I'll send the word out when I get my brackets on the 29th.
Old Jul 23, 2004 | 01:08 PM
Grimm's Avatar
Default Re: (RusBear)
my confusion on this is why can't you buy a bracket for the seat from the manufacturer for your car?
Old Jul 23, 2004 | 01:36 PM
RusBear's Avatar
Default Re: (Grimm)
Can't find what I need! Del Sol brackets that I did looked like something that definitely would not fit my seats. I need a bracket with two parallel intersecting flat steel beams that have holes on the bottom for floor bolts. Hard to explain, this looks exactly like what I need: http://www.prostreetonline.com...ckets/
If I had something like that, I would just bolt the bracket to the bottom of the rails that came with seat, done and done.
Old Jul 30, 2004 | 06:36 PM
RusBear's Avatar
All right, time to settle it once and for all. Got my brackets, and guess what?
Yup, they definitely do not fit. One hole, yes; the rest do not match up at all, the holes in the floor are spaced too close, and the back ones are too low on the floor. So much for thinking my CIVIC del Sol was a Civic.
I see a lot of fumbling, drilling, and welding in my future...
mskansan
12
Mar 15, 2008 11:20 PM
DavidNA2FI
Jan 19, 2008 07:37 AM
IDGAF2885
Jul 14, 2007 04:53 PM
sykotik sol
Nov 16, 2005 07:06 PM
12SecHatch
Nov 19, 2002 12:07 AM
