B16 Ecu Diagram Questions????
Old Jul 22, 2004 | 01:34 AM
SkunkCrxSi's Avatar
Default B16 Ecu Diagram Questions????
hey i just got a Complete B16 Sir1 swap from hmotorsonline.com and i have heard from various places that you have to change the pinouts on the ecu... i was wondering if anyone could help me out with a diagram and if you had any idea on what wires to change...? Any experienced input would be greatly apreciated
Old Jul 22, 2004 | 01:36 AM
SkunkCrxSi's Avatar
Default Re: B16 Ecu Diagram Questions???? (SkunkCrxSi)
Im sry its the PR3 ecu
Old Jul 22, 2004 | 04:47 AM
crx_88_si's Avatar
which car is this going into?
Old Jul 22, 2004 | 07:30 AM
SkunkCrxSi's Avatar
Default Re: B16 Ecu Diagram Questions???? (crx_88_si)
im sorry i forgot to mention its goin into a 89 Crx si..
Old Jul 22, 2004 | 08:43 AM
crx_88_si's Avatar
I believe you just add the vtec solenoid, vtec oil psi, knock sensor and the 2nd o2 to the harness.
Old Jul 22, 2004 | 08:46 AM
crx_88_si's Avatar
Here's a little pic that should help you out.
manson's Avatar
Default Re: (crx_88_si)
i have a single wire zdyne ECU for sale.... check my signiture for the link.
Old Jul 25, 2004 | 11:09 PM
SkunkCrxSi's Avatar
what do i do with the wires that are already in the the plug? i bought the HAsport sub harness...
Old Jul 25, 2004 | 11:20 PM
spaceman's Avatar
Default Re: (SkunkCrxSi)
it should have came with instructions..get an ecu pin tool if you dont have one,it will make it ez..check out hasport.com
Old Jul 26, 2004 | 05:58 AM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkunkCrxSi &raquo;</TD></TR><TR><TD CLASS="quote">what do i do with the wires that are already in the the plug? i bought the HAsport sub harness... </TD></TR></TABLE>
there are no wires in pins A8 and C8 on the Si - B5 & B19, you just disconnect - not used on B16 - B5 is alternator reference signal and B19 is electric load detector
Soon2DriveACivic
Jun 11, 2005 12:56 PM
folta2169
Dec 17, 2004 09:18 AM
hybrid1990crx
Nov 19, 2004 11:00 AM
TooDrunk2See
Sep 22, 2003 02:49 AM
