Suspension: Can I swap my 92-95 Civic/Integra Rear Koni shocks into my 89 HF (fork style)
Old Jul 21, 2004 | 09:12 PM
spoonfed407's Avatar
Default Suspension: Can I swap my 92-95 Civic/Integra Rear Koni shocks into my 89 HF (fork style)
Basically I tried it myself this afternoon and I thought for sure it works judging by some of the responses on here... But I don't know if its just my but the trailing arm of the rex was a little bit thicker as a result the shock could not fit correctly to be bolted.... Am I wrong ? thanks
Old Jul 22, 2004 | 11:47 AM
SpoonFed's Avatar
Default Re: Suspension: Can I swap my 92-95 Civic/Integra Rear Koni shocks into my 89 HF (spoonfed407)
ttt
Old Jul 22, 2004 | 11:55 AM
Todd00's Avatar
I said I don't want a title!
The rear shocks on the 89-95 Civics, 94-01 Integras were all pretty much identical.
Old Jul 23, 2004 | 03:48 AM
talking about Konis ? or stock shocks
Old Jul 23, 2004 | 05:47 AM
REDBARON's Avatar
I used my 99 Tokico shocks on my rex before, and those shocks came with some rather thick washers that go in between the shock, and LCA on both side of the fork. Just to clarify, the washer went on the outside of the LCA, but on the inside of the shock fork. You just hold one washer at a time while putting in the thru bolt.
Old Jul 23, 2004 | 06:47 AM
crx_88_si's Avatar
aren't 92+ suspensions a little longer?
Old Jul 23, 2004 | 08:33 AM
Default Re: (crx_88_si)
longer isn't a problem but I understnd what you are saying "REDBARON" about the washers in b/t the shock and LCA... But the problem is the LCA looks/is too thick for the fork of the shock to fit over it///
Canadian_EF
Suspension & Brakes
Aug 5, 2009 09:51 PM
bigpimpintsx
Acura TSX
Jul 3, 2007 08:00 PM
Mario.
May 31, 2004 04:58 PM
xdavidx
Mar 4, 2004 10:40 AM
Bumnah
Jan 3, 2002 06:21 PM
