CA 'enhanced' smog test results
Old Jul 21, 2004 | 08:41 PM
sharkcohen's Avatar
Default CA 'enhanced' smog test results
2000 Prelude Sportshift
50k miles
JRSC
550 cc injectors
EFI Systems PMS
NGK BCPR7ES-11 spark plugs
stock intake with resonator
stock header
stock cat
stock exhaust
factory cap, rotor, and wires
Code:
HC (PPM)
Test          MAX   AVE   MEAS
15 mph   55    9     5
25 mph   39    7     2
CO (%)
Test          MAX   AVE   MEAS
15 mph   .50   .02   .00
25 mph   .48   .03   .01
NO (PPM)
Test          MAX   AVE   MEAS
15 mph   437   57    27
25 mph   724   50    0
Old Jul 21, 2004 | 08:43 PM
sharkcohen's Avatar
Default Re: CA 'enhanced' smog test results (sharkcohen)
Crap, 'code' is disabled/unusable. Well, you guys figure it out
Old Jul 21, 2004 | 08:45 PM
satan_srv's Avatar
did you have your SC belt taken off as well? or does the rpm level stay out of boost anyway?
Monkey Fing a Coconut's Avatar
HOLY ****!!!!! is ur exhaust secretly going somewhere else when they put the sensor in ur muffler??? is there even combustion or are u using some fuel other than gasoline??? WHERE ARE ALL THE EMISSIONS AT?!?!?!?!?!
Old Jul 21, 2004 | 08:55 PM
98TypeSH's Avatar
Default Re: CA 'enhanced' smog test results (twistedbydezign)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">did you have your SC belt taken off as well? or does the rpm level stay out of boost anyway?</TD></TR></TABLE>
I was under the impression that with a super charger, you were in boost the second you hit the throttle. am i nucking futs ?
Old Jul 21, 2004 | 08:58 PM
Default Re: CA 'enhanced' smog test results (98TypeSH)
u always have boost however at low rpms its so low that its insignificant, u dont have a constant peak 6 psi or whatever at all rpms
Old Jul 21, 2004 | 09:31 PM
sharkcohen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twistedbydezign &raquo;</TD></TR><TR><TD CLASS="quote">u always have boost however at low rpms its so low that its insignificant, u dont have a constant peak 6 psi or whatever at all rpms</TD></TR></TABLE>
The JRSC has a vacuum actuated bypass valve that recirculates the boost in the manifold, so the engine can operate at vacuum under low load/throttle.
No, the blower belt was still installed. I was very surprised, when he ran the test on the dyno the loads applied were so small that the car never once went into boost. This was all vacuum, closed loop operation.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH &raquo;</TD></TR><TR><TD CLASS="quote">I was under the impression that with a super charger, you were in boost the second you hit the throttle. am i nucking futs ?
Depends on how much throttle you give it. You can drive around all day long without boosting.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twistedbydezign &raquo;</TD></TR><TR><TD CLASS="quote">HOLY ****!!!!! is ur exhaust secretly going somewhere else when they put the sensor in ur muffler??? is there even combustion or are u using some fuel other than gasoline??? WHERE ARE ALL THE EMISSIONS AT?!?!?!?!?!</TD></TR></TABLE>
ROFL, just standard, craptacular CA 91 octane You'd be surprised, these OBDII cars are low emissions vehicles. During closed loop operation the ecu keeps a/f in absolute check, the EGR system does its job, and the stock catalytic converters are very well made.
Another thing to keep in mind is that the guy that I went to turned out to know his **** real well. He had my car idle for 20 minutes and then ran it at 2000 rpm in park for about 10 minutes to make sure that the engine and cat were at operating temperature to ensure that the test was accurate. This is something that all shops are supposed to do, but many do not.
Modified by sharkcohen at 10:41 PM 7/21/2004
Old Jul 21, 2004 | 11:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">
i'll have to make sure the ref does that when i go in to get my h22a ref'd on friday for my 93 accord...i got all the smog parts hooked up, just need to pass the emissions part, in addition to CA 91 octane(grr...) i'm gonna put in some xylene which has no emissions i have read (like putting rubbing alcohol in the gas...)
Old Jul 22, 2004 | 04:39 AM
iakona's Avatar
shark, where did you go in the East Bay for such great service?
Old Jul 22, 2004 | 05:16 AM
sharkcohen's Avatar
Default Re: (iakona)
Bay Smog in Hayward. It's a test only station, so if you fail he won't be able to do any repairs, but the guy is very knowledgeable, he would be able to tell you what needs to be repaired for it to pass.
MugenDC4
Apr 12, 2008 10:34 AM
shorto85
Jan 19, 2005 10:27 PM
88LXiProject
Oct 20, 2003 09:56 PM
88LXiProject
Oct 2, 2003 10:40 AM
