blinker mirror problem
i have a problem with myt blinker mirrors. i have them all wired up into the front turn signal wiring. but i also have the halo head lights hooked into the parking lights as well. the mirrors jsut light up like parking lights and dont blink. and if they do blink only 1 out of the four l.e.d's ligth up. do you think that with the halo's and the blinkers wired inot the same thing its pulling to much power and thats why they arent lighting up fully?
what color wires did you tap into nublet?
There are 3.
1. Ground
2. <FONT COLOR="red">Blinker power</FONT>
3. <FONT COLOR="green">Parking light power</FONT>(constant 12v,switch ON)
There are 3.
1. Ground
yeah i have all the wiring right im 90% positive. they light up but dont blink right witch i dont get becuase they have power so the red and black wires are obviusly hooked up right and i know the green is hooked up also.
LOL!
theres your problem buddy.
Your sidemarker is a single fillament bulb. which means it cannot light up and blink like your corner light does.
you have 2 simple options:
1. hook up the sidemarkers to be on with your corner lamps
2. hook up the sidemarkers to blink with your turn signal.
if you want both, you'll need some relays, and some time. and some electrical knowledge.
I'm really suprised no one is flaming u yet. Have u tested to see if the lights even work at all. Get the positive and negative wires and touch them to the battery just to see if they light up. And u said u have the mirrors hooked up to the blinkers and the halos hooked up to the sidemarkers. But then u said u have them hooked up to the same thing so which one is it?
