Help - Exhaust header fit for ITR motor swap into GSR with stock gsr cat and exhaust
Old Jul 21, 2004 | 08:20 PM
96_GsR_BlownEngine's Avatar
Default Help - Exhaust header fit for ITR motor swap into GSR with stock gsr cat and exhaust
Just like topic says:
Putting in a type R longblock in 4-door GSR and I am planning to get some type of header and eventually an aftermarket exhaust for the swap.
I would like to get the headers first and run the car for a while with the stock GSR exhaust and cat if possible.
Will most headers bolt right up to the flange on the GSR cat? Will the exhaust need to be modified to make this happen?
Or, If I simply buy an aftermarket exhaust now, will the cat length and flanges be correct without any mods?
Thanks
Old Jul 21, 2004 | 08:33 PM
redman223's Avatar
Default Re: Help - Exhaust header fit for ITR motor swap into GSR with stock gsr cat and exhaust (96_GsR_Blo
When I first got my swap, I think I had a stock b16 exhaust manifold on there (or maybe from the integra LS), and used the stock eg cat/exhaust and it bolted right up.
But before I went to the smog place to get ref'd I went on the classifieds and bought a stock gsr exhaust manifold, cat, and exhaust, it all bolted up just fine on my 94 hatch. So for your application a stock GSR exhaust manifold will fit just fine. I would imagine any header made to fit the GSR would fit also.
Old Jul 22, 2004 | 05:41 PM
Thanks
That sounds almost too easy to be true
I guess that the exhaust manifold bolt / orifice pattern is the same on any b16 or b18c head....
Modified by 96_GsR_BlownEngine at 11:17 PM 7/22/2004
Old Jul 22, 2004 | 08:11 PM
redman223's Avatar
Yeah it is, people usually just rig them up different so that they dont have to buy all new stuff right away.
Pinner13
Oct 5, 2010 12:36 PM
Xymox007
Mar 8, 2004 08:19 PM
Grandprix
Jan 29, 2004 05:34 PM
AintegraA
Dec 18, 2003 02:18 PM
BlackAC99
Nov 14, 2002 09:00 AM
