ZC
Old Jul 21, 2004 | 08:12 PM
neogeo's Avatar
Default ZC
hey
I'm probably getting a 88 crx SI soon and it already has a ZC engine in it, but no wiring harness. what one do I need? can I get it at a junkyard?
Thanks, Eric
Old Jul 21, 2004 | 08:16 PM
mr_valentino20032000's Avatar
Default Re: ZC (neogeo)
i've always heard to use a slightly modified Si harness...the diffrence is two wires
Old Jul 21, 2004 | 08:47 PM
neogeo's Avatar
Default Re: ZC (mr_valentino20032000)
how do I "slightly modify" it?
Old Jul 21, 2004 | 09:29 PM
cbrodac0424's Avatar
use search u will find everything u need
Old Jul 21, 2004 | 10:33 PM
neogeo's Avatar
Default Re: ZC (cbrodac0424)
ok one more thing for my dad's sake. are there any problems or troubles with this engine or anything of the like? and lastly how much would a harness cost?
Old Jul 21, 2004 | 10:36 PM
JapJunkie's Avatar
hit up junkyards, around $50-60 for a harness
Old Jul 21, 2004 | 10:39 PM
civicdxzc's Avatar
What do you mean by problems or troubles. If you would like to avoid problems i would chang out your normal wear items such as: timing belt, water pump, plugs, wires, etc, you get the idea. to find part numbers and such http://www.thezcr.com/html/partnums.php.
For that help i accept hand jobs or potato chips (sour cream) for payment.
Old Jul 21, 2004 | 10:45 PM
hahagasdcrx's Avatar
Default Re: (civicdxzc)
You need the engine harness out of the same year crx si. You might be able to use the 89 crx si. Also you need to move the 2 white wires on the distributor plug(7 wire plug) to the No.1 cyl sensor on the exhaust cam side of the zc (if its the dohc zc).
Old Jul 21, 2004 | 10:58 PM
neogeo's Avatar
Default Re: (hahagasdcrx)
beauty thanks for the help............now I gotta see about uhaulin this thing home.
Old Jul 22, 2004 | 09:44 AM
neogeo's Avatar
Default Re: (neogeo)
oh one last question......does the zc fit under the stock hood? because I've seen ones with buldges
Old Jul 22, 2004 | 10:05 AM
LudeEFv2.4's Avatar
My old title sucked.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neogeo &raquo;</TD></TR><TR><TD CLASS="quote">oh one last question......does the zc fit under the stock hood? because I've seen ones with buldges</TD></TR></TABLE>
Yes. The overseas cars have different engine mounting points.
Old Jul 22, 2004 | 11:20 AM
hatchinprogress's Avatar
a si harness will work fine
Old Jul 22, 2004 | 01:33 PM
beavis's Avatar
an si with slight modification and a resistor box
Old Jul 23, 2004 | 05:41 PM
neogeo's Avatar
Default Re: ZC (ZCed89hatch)
resisitor box? what ? how do I hook it up? where do I get one? can someone please list everything I'm going to need to make this run?
Old Jul 23, 2004 | 06:03 PM
ServiceAdvisor's Avatar
Stock Si harness and 2 wires from the dizzy moved to the Cam Angle sensor on the exhaust cam passenger side of the motor is all you need. And remember, your stock Si AC should bolt right up great little thang that ZC. My DOHC ZC pulls sick like and being non-VTec sure puts a puzzling look on peoples faces when I explain its a DOHC 1.6 non-VTec. Also, make sure to use either of these three ecu's decending in order of preference by most: 1. Stock ZC ecu &lt;~ Rare, 2. 88-89 UDSM Integra 5spd &lt;~ Better Fuel curves, 3. Stock Si ECU. - Darrell
Old Jul 23, 2004 | 06:55 PM
neogeo's Avatar
Default Re: (OldSiHatch)
how quick is it with the zc? (as a first car)
Old Jul 23, 2004 | 07:35 PM
neogeo's Avatar
bump
Old Jul 23, 2004 | 07:57 PM
neogeo's Avatar
c'mon noone can tell me if their dohc zc is quick?
bumpy
Old Jul 23, 2004 | 08:36 PM
T-Mo's Avatar
Its decent for the money. I love it. My boyfriend has it in his. We were riding the other night after they "tweaked" it and he was doing 85mph in 3rd gear on a PM6 ECU.
I had a b18b that I was going to do, but I sold it here on Honda-tech because I had lost my job. Now I may go with a d-series vtec engine or the DOHC ZC.
Old Jul 23, 2004 | 08:43 PM
neogeo's Avatar
Default Re: (T-Mo)
kool do you think its a good deal for an 88 crx si dohc zc that just needs a wiring harness (and has a racing clutch)?
Old Jul 23, 2004 | 08:50 PM
T-Mo's Avatar
It depends on the price. In my state, they are popular among the Honda scene, and go for anwhere from $200-2500 w/swaps, but other places can go as high as $4000 for any SI w/swaps.
Old Jul 24, 2004 | 06:53 PM
neogeo's Avatar
Default Re: (T-Mo)
well the car is up for $600 (canadian) (will probably get it down to 500.......my dad would never let me pay full price for anything lol )
Lil ZC
14
Feb 11, 2011 12:27 AM
HondaHemi
Apr 25, 2006 02:36 PM
Dspad_91Civic
May 7, 2004 05:12 PM
SIRX
11
Jan 13, 2003 06:29 AM
vtec_head
May 8, 2002 08:59 AM
