Air fuel ratio for a NA B18C1
Old Jul 21, 2004 | 08:06 PM
95 integra's Avatar
Default Air fuel ratio for a NA B18C1
Yes I searched and found....mostly stuff for turbo'd cars. Im currently under the belief that my A/F should be around 13.0-13.5 under WOT.
Mods are:
P&P head
P&P gsr IM
Toda A cams
AEM V2
JDM ITR header
2.5" straight exhaust
11.3:1 CR
misc other stuff.
Tuning with Hondata
What should my A/F ratio be?
Old Jul 21, 2004 | 08:44 PM
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: Air fuel ratio for a NA B18C1 (95 integra)
get an a/f gauge you woulent have to guess then....
Old Jul 21, 2004 | 09:06 PM
AngelR's Avatar
Yes, that's a good range to shoot for.
Old Jul 21, 2004 | 10:39 PM
JDMlyfestyle's Avatar
13.7 to 14.0 is what i see alot so im assuming thats what everyone aims for.
Old Jul 21, 2004 | 10:45 PM
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: (JDMlyfestyle)
if i guess i said about the same as he 14ish
Old Jul 21, 2004 | 10:48 PM
johnzm's Avatar
Default Re: (FastAllmotorLsVtec)
whereever it makes power
Old Jul 22, 2004 | 06:09 AM
eg92b16a2's Avatar
Default Re: (johnzm)
check out this site...
http://www.importbuilders.com
Old Jul 22, 2004 | 06:57 AM
ce's Avatar
ce
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">Yes I searched and found....mostly stuff for turbo'd cars. Im currently under the belief that my A/F should be around 13.0-13.5 under WOT.
Mods are:
P&P head
P&P gsr IM
Toda A cams
AEM V2
JDM ITR header
11.3:1 CR
misc other stuff.
Tuning with Hondata
What should my A/F ratio be?</TD></TR></TABLE>
Only the dyno will tell
Rule of thumb isthat NA Hondas like 13.5 or so and that's what I've had the best results with so far..But go to a dyno and see where it makes most power
Old Jul 22, 2004 | 12:55 PM
Team 4's Avatar
Default Re: Air fuel ratio for a NA B18C1 (ce)
I made peak power at 13.4:1
Old Jul 22, 2004 | 12:59 PM
AllMota86's Avatar
What about with Race Gas, Im using 110 Octane and my Air Fuels are around 13.0, I havnt tuned the car yet on the Dyno but baseline was at 230 hp @161 ft lbs. Maybe I will try leaning it out alot more and seeing if it will make more power. My plugs seem pretty white at 13.0 though.
Old Jul 22, 2004 | 06:37 PM
95 integra's Avatar
Default Re: Air fuel ratio for a NA B18C1 (FastAllmotorLsVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FastAllmotorLsVtec &raquo;</TD></TR><TR><TD CLASS="quote">get an a/f gauge you woulent have to guess then....</TD></TR></TABLE>
Im going to have an O2 sensor, but Ill still be guessing as to where I NEED to set the A/F ratio. The only problem I have with the "wherever maximium power is", is that I want a good mix of power and reliability. I dont want to hear, well just set it to 12:1 or well 14.7:1 is the "optimum" point either....I want to hear reasonable suggestions. Im glad to see that I am getting resonable replies of around 13.5+/- .5 though, so thats probably where ill be starting from and going a little leaner or richer.
Old Jul 22, 2004 | 07:07 PM
johnzm's Avatar
unfortunatly, with my b16 build i had a tuner who wanted to be SAFE. well truthfully, i would rather have 5 more whp all over than to be at "my favorite a/f"
so as i saw him dial it into a solid a/f there was a lean spot left and right at that spot HP was up bout 4whp unfortunatly, i coudlnt gety him to move my a/f curve all to that, so this time im tuning it myself
Old Jul 22, 2004 | 07:15 PM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">13.7 to 14.0 is what i see alot so im assuming thats what everyone aims for.</TD></TR></TABLE>
WAY TO LEAN.....play it safe.....13.0-13.5
Old Jul 22, 2004 | 07:17 PM
chad's Avatar
Moderator
Default Re: (chad)
tune to power but make it safe.....if it makes most power at 13.7 i'd drop it down to 13.4 ish.....BE SAFE....make the engine last!!
Old Jul 23, 2004 | 04:25 PM
95 integra's Avatar
Default Re: (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">tune to power but make it safe.....if it makes most power at 13.7 i'd drop it down to 13.4 ish.....BE SAFE....make the engine last!!</TD></TR></TABLE>
Thats what Im saying. Either way, the guy I was going to take it to seemed a little to happy about peak power for my personal preference, so to atlanta I drive. Anyway, if a tuner wont tune it to YOUR specs then it might be time to find a new one. Thats what I did....the guy didnt seem like if I told him to tune it to 13.0:1 that he would, so Im going to somebody else.
Old Jul 24, 2004 | 07:35 PM
AzG35's Avatar
Default Re: (95 integra)
Also remember that when you tune a car on a dyno, it will inherently run leaner on the street.
Old Sep 28, 2004 | 07:09 AM
631 Teggy's Avatar
Default Re: (AzSi22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzSi22 &raquo;</TD></TR><TR><TD CLASS="quote">Also remember that when you tune a car on a dyno, it will inherently run leaner on the street. </TD></TR></TABLE>
Why is that? (I'm not refuting you, I have just never heard of this...)
Old Sep 28, 2004 | 07:59 AM
ce's Avatar
ce
because there's a lot more air flow when moving at 100+ mph than on a dyno with just a huge fan blowing at the car
On the dyno go for 13:1 or so..
When I wideband tune I aim for 13.4-13.5 or so..
Old Sep 28, 2004 | 08:37 AM
WAFFLES's Avatar
correct.
I made power around 13.8:1 when I dynoed recently. I dropped it down to about 13.2:1 and put it on the road.
Old Sep 28, 2004 | 08:38 AM
WAFFLES's Avatar
Default Re: (ce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ce &raquo;</TD></TR><TR><TD CLASS="quote">because there's a lot more air flow when moving at 100+ mph than on a dyno with just a huge fan blowing at the car
When I wideband tune I aim for 13.4-13.5 or so..</TD></TR></TABLE>
also because there is a load being placed on the engine, so it has to work harder to accelerate the car then on an unloading dyno.
Old Sep 28, 2004 | 09:33 AM
AzG35's Avatar
Default Re: (WAFFLES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WAFFLES &raquo;</TD></TR><TR><TD CLASS="quote">
also because there is a load being placed on the engine, so it has to work harder to accelerate the car then on an unloading dyno.</TD></TR></TABLE>
This is correct as well, there will be other factors on the road vs. the dyno, ie. wind, vehicle weight, air conditions etc.
Old Sep 28, 2004 | 10:48 AM
95 integra's Avatar
Mine was tuned to about 13.2.
compprat
May 20, 2006 09:56 AM
Komakazi_830
Jan 27, 2006 11:07 AM
CivicHatchback14
Mar 21, 2005 02:18 PM
J-Spec EG
Oct 22, 2004 10:19 AM
radeon
Aug 22, 2004 07:05 AM
