going to drop my car, got some questions
Old Jul 21, 2004 | 06:20 PM
jadugartir's Avatar
Default going to drop my car, got some questions
When i bought my hatch the front springs were cut, so i decided the first thing i was going to do was drop my car the right way... I searched for something that would show me all about what i need to do, but i couldnt find anything so if anyone has a link or some information id appreciate it. I know i need a new ball joint and upper control arm on the drivers side, so do i need to do replace that first? Im going for a minimum 1.6 drop in front and 1.5 in back. The main thing i want to know is what do i need to buy and in what order do i put them on or does it matter. Will i still use the struts i bought from autozone or do i need new ones, or will i have a different setup
Old Jul 21, 2004 | 06:23 PM
DXDOHCVTEC's Avatar
Default Re: going to drop my car, got some questions (jadugartir)
If you plan on replacing the struts with the springs it will be an easier job. If the springs are cut chances are the shock that are on it are blown.
Old Jul 21, 2004 | 06:27 PM
jadugartir's Avatar
Default Re: going to drop my car, got some questions (DXDOHCVTEC)
the shock? if thats part of the strut then it should still be ok as ive driven only about 500 miles since i replaced all 4 struts. If the shock is a seperate thing then i apologize for my ignorance.
Old Jul 21, 2004 | 06:32 PM
manson's Avatar
best order is all at once. i personally like Ground Control coilovers they can be adjusted to any height and you can swap out the springs to firmer ones if you get into auto cross or drag racing whatever. i also use KYB AGX shocks and they have done me well. when you use them correctly like following the manufactures limits they work great. check my garage https://honda-tech.com/gara...04025 to see my height at there suggested lowest setting...looks good to me.
i think for the $ its the best setup. and if you get winter you can raise it up so your not a plow...
EDIT... if you just bought all 4 new shocks just drop it like an 1" or 1 1/4" they should last sometime, but not very long. better off pulling them off selling them and buying stronger ones like KYB or Koni.
Old Jul 21, 2004 | 06:36 PM
zad5's Avatar
get some omnipower coilovers full coilover system not threaded for a real good price. i believe the site is omnipowerusa.com
Old Jul 21, 2004 | 06:52 PM
jadugartir's Avatar
Default Re: (zad5)
alright say i bought those omnipower coilovers, they come $199 shipped, thats all i need? will they replace my current springs and struts? will i need anything else? what will i take off my car
Old Jul 22, 2004 | 08:01 AM
jadugartir's Avatar
Default Re: (jadugartir)
my local shop just tried to sell me some no name coilovers for 200 installed, should i hold out for better ones and install them myself?
Old Jul 22, 2004 | 10:11 AM
REDBARON's Avatar
Yes you should. No name coilovers don't have the option to change the spring rates to your likings like Ground Control do.
It's not that hard to install man, believe me.
Old Jul 22, 2004 | 10:55 AM
temp's Avatar
Default Re: (REDBARON)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by REDBARON &raquo;</TD></TR><TR><TD CLASS="quote">Yes you should. No name coilovers don't have the option to change the spring rates to your likings like Ground Control do.
It's not that hard to install man, believe me. </TD></TR></TABLE>
but that doesnt mean you cant buy the other springs from GC or a like company and put them on your no name sleeves
Old Jul 22, 2004 | 01:44 PM
zad5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jadugartir &raquo;</TD></TR><TR><TD CLASS="quote">alright say i bought those omnipower coilovers, they come $199 shipped, thats all i need? will they replace my current springs and struts? will i need anything else? what will i take off my car</TD></TR></TABLE>
omnipower sleeve coilover like ground control cost 200 but ur gonna need struts.
the full coilovers is what i think you should get cost 699. i thought they were a little cheaper but i geuss not mayb e if you serach aroudn or ask omniman that his username on honda-tech. good luck man
Old Jul 22, 2004 | 01:48 PM
HondaKPX's Avatar
Default Re: (zad5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zad5 &raquo;</TD></TR><TR><TD CLASS="quote">
the full coilovers is what i think you should get cost 699. i thought they were a little cheaper but i geuss not mayb e if you serach aroudn or ask omniman that his username on honda-tech. good luck man</TD></TR></TABLE>
Might as well get yourself a set of tein basic dampners for that mutch.
Old Jul 22, 2004 | 01:50 PM
spyz34's Avatar
Default Re: (HondaKPX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKPX &raquo;</TD></TR><TR><TD CLASS="quote">
Might as well get yourself a set of tein basic dampners for that mutch.</TD></TR></TABLE>
Ya but comparing the 2, it seems the omnipower are a better buy. Dont they have adjustable damper too. The basics dont and are more expensive.
Old Jul 22, 2004 | 02:10 PM
zad5's Avatar
i bleieve omnipower do not have adjustable damper but the valving and spring rate is going to be better then tein basics.
mackinit
Feb 17, 2011 03:38 PM
Youngblood27
31
Aug 24, 2010 10:59 AM
mattmw88
Mar 20, 2006 02:30 PM
silvercivicgrl
Sep 11, 2002 06:18 PM
95civic
Sep 7, 2001 07:29 PM
