Do I need a D16Z6 ECU
Old Jul 21, 2004 | 06:15 PM
enochnich's Avatar
Default Do I need a D16Z6 ECU
I've posted a few questions on here about my CRX I'm new to this stuff. I have a 89 CRX Hf with a 95 Civic D16Z6 SOHC VTEC and someone told me that I have to have the 95 Civic ECU in my 89 Hf or it will mess up my engine but the engine is in and running stong. So are they stupid or what?
Old Jul 21, 2004 | 06:25 PM
slywfbpsi's Avatar
Default Re: Do I need a D16Z6 ECU (enochnich)
How are you activating vtec?
Old Jul 21, 2004 | 06:36 PM
Rywire's Avatar
Default Re: Do I need a D16Z6 ECU (slywfbpsi)
search ebay p28
Old Jul 21, 2004 | 06:40 PM
-slow ej-'s Avatar
Default Re: Do I need a D16Z6 ECU (droppedcrxsi)
orrr partstrader peetwentyeight
Old Jul 22, 2004 | 09:38 AM
enochnich's Avatar
what do you mean how am I activating VTEC?
dont know much about this stuff
Old Jul 22, 2004 | 09:46 AM
REDBARON's Avatar
Well if you have a SOHC VTEC motor, your HF ecu is not going to activate VTEC since it was designed to do that. Also it's going to be running the fuel, and spark maps for the HF which are also not ideal for the D16Z6 that's in your car. I would do a search on here about the SOHC VTEC (D16Z6), to see which way you would like to go to activate VTEC. Some of the options are: Install a RPM activated switch, go to ODD-1 and get the D16Z6 ecu, etc..
Do a search. It's obvious that you're not familiar with the full capabilities of that motor.
Old Jul 22, 2004 | 09:48 AM
REDBARON's Avatar
Default Re: Do I need a D16Z6 ECU (REDBARON)
Oh, I forgot to answer you question.
No they are not stupid. I don't think you'll mess up the motor by running it with the HF ecu, but you won't be able to realize the full potential of the motor with that ecu.
Old Jul 22, 2004 | 11:59 AM
rob42386's Avatar
Well he is definetly not using the HF ecu!!
There is no way that the PM8 can support that motor, unless he is redlining at 5500!!
More than likely did you buy the car this way??? It probably has a PM6 si ecu in it.
With the PM8 you get all the exhaust bullshit codes!
Old Jul 22, 2004 | 06:27 PM
enochnich's Avatar
I can get the 95 Civic ECU but the Civic was a automatic also would it plug directly into the plug ends on my hf or would I have to ******-rig-it(no offense) What would be the cheapest way to get the VTEC working I'm on a tight budget.
Old Jul 22, 2004 | 06:45 PM
slywfbpsi's Avatar
no it will not plug into it, you need to search on odb0 to odb1 conversion for that answer. there is no cheap route for you since you are still using the hf ecu, so, either source a pm6 or something like that and rund an msd switch to activate vtec, but since you may or may not be running a z6 dizzy, then you have to source a p28 an an odb0 -> odb1 conversion harness.
Old Jul 22, 2004 | 08:14 PM
92integra_gs's Avatar
did you buy this crx like this if so what did the previous owner say about the engine?
check your ecu and let us know what is the code you find labeled there... its located in your passenger side under the carpet under the glovebox... and does it look like your distributor got any custom mounts on it..
we need to figure out what obd system you got running in your car now.. so we can better help you...
Old Jul 23, 2004 | 08:49 AM
enochnich's Avatar
Default Re: (92integra_gs)
Before I bought the car it had been sitting in a field for about 3 years. The people I bought it off of dosent know jack squat. The # on the ECU is **37820-PM6-A09** and below that is reads **620-329917 MK** the distributor is out of a D16A6 but I have 2 D16Z6 distributors. The A6/Z6 distributors have the same amount of wires but they are coated two diffrent colors. Can you cut the plugends off & wire the the A6 plugend to the Z6 distributor??
Old Jul 23, 2004 | 08:59 AM
Dwight Schrute's Avatar
Default Re: (enochnich)
ur running a pm6 (crx si ecu) . since ur already obd and have it running , i would just use a vtec activated switch, fields vtec controller, or vafc. you would just use ur a6 dizzy which im assuming u are still using unless u wired for obd1.
Old Jul 23, 2004 | 10:48 AM
enochnich's Avatar
Default Re: (drewthomas14)
where could I get that VTEC stuff?
Old Jul 23, 2004 | 10:56 AM
520_Motorsports's Avatar
use your pm6(Si) ecu and a V-AFC or send your ecu to hasport and get a zdyne computer. you can get a V-AFC at your local performance retailer. or just use a PW0 or a PR3 you cannot use a P28 or any obd1 ecu unless you use an obd1-obd0 conversion harness. Just stay obd0
Old Jul 23, 2004 | 06:50 PM
enochnich's Avatar
Default Re: (fastlx-i)
Just a small question. What is a V-AFC or a PW0 or a PR3 ?
Im stupid
Old Jul 24, 2004 | 05:59 AM
slywfbpsi's Avatar
dude, a v-afc is a vtec fuel controller that you can buy made by Apex'i. a pw0 and a pr3 are vtec odb0 ecus used for the b16a in 88-91 cars.
Old Jul 24, 2004 | 01:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by enochnich &raquo;</TD></TR><TR><TD CLASS="quote">Before I bought the car it had been sitting in a field for about 3 years. The people I bought it off of dosent know jack squat. The # on the ECU is **37820-PM6-A09** and below that is reads **620-329917 MK** the distributor is out of a D16A6 but I have 2 D16Z6 distributors. The A6/Z6 distributors have the same amount of wires but they are coated two diffrent colors. Can you cut the plugends off & wire the the A6 plugend to the Z6 distributor?? </TD></TR></TABLE>
just stay obd-0.... you will spend more if you convert to obd-1.. you just need a vtec controller.. but be advised the cost about $100 -$200....
you're car is running strong... and doesnt have anything wrong... and some dumbass goes up to you and says you need a d16z6 ecu (p28) to ran this car... he obviously dont know ****.. i mean if your is running the way you say it is why would even touch it... you just need to add to it to enhance the vtec feature that you got....
o btw(by the way) if you chance your A6 dizzy(distributor) to a Z6 dizzy you will absolute need to change to obd1
Old Jul 24, 2004 | 07:14 PM
enochnich's Avatar
Default Re: (slywfbpsi)
where can I get a V-AFC???
Old Jul 24, 2004 | 07:39 PM
SECURITY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by enochnich &raquo;</TD></TR><TR><TD CLASS="quote">where can I get a V-AFC???</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastlx-i &raquo;</TD></TR><TR><TD CLASS="quote">you can get a V-AFC at your local performance retailer. </TD></TR></TABLE>
There are 2 major brands of these: Fields and Apexi
http://cgi.ebay.com/ebaymotors...33596
for example
But...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by enochnich &raquo;</TD></TR><TR><TD CLASS="quote">I'm on a tight budget. </TD></TR></TABLE>
And VTEC controller is gonna cost you $200 and up. This whole obd0 - obd1 crap can get pretty complex so I would suggest that if your car is running and you can drive it then don't mess with it. You have a VTEC engine in there but you're not hitting VTEC right now, but who cares anyways, it's still faster then stock.
You're going to spend upwards of $500 to go obd1 after the boomslang harness, p28, TD-042(?) distributor, z6 intake manifold, obd1 injectors, and everything I forgot has been collected and installed.
So go punch that kid in the nuts!
Old Jul 24, 2004 | 07:45 PM
SECURITY's Avatar
Default Re: (oh_crx)
One more thing I drove my d16z6 around for more than 5000 miles before converting to obd1 to pass the smog refs. I had my obd0 dizzy, pm6, and obd0 injectors in there, but it ran beautifully. I wasn't hitting VTEC but the car would still pull after 5,000 rpms. Who knew!
Old Jul 24, 2004 | 09:01 PM
Gant's Avatar
damn u bought this car not knowing anything about the engine
Old Jul 25, 2004 | 04:00 AM
shop around for a vtec controller....
i got my fields vtec controller here on H-T for $90 shipped.... which normally cost $150-200
Old Jul 25, 2004 | 06:47 AM
enochnich's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integra_gs &raquo;</TD></TR><TR><TD CLASS="quote">shop around for a vtec controller....
What website is that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ba4 &raquo;</TD></TR><TR><TD CLASS="quote">damn u bought this car not knowing anything about the engine </TD></TR></TABLE>
yep I've wanted a rex ever since I was 8 years old & and they are very rare here where I live
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oh_crx &raquo;</TD></TR><TR><TD CLASS="quote">
for example
So go punch that kid in the nuts! </TD></TR></TABLE>
Please NNNOOOO I'll need those a while longer LOL
jfrase06
May 19, 2007 07:04 PM
TehMoonRulz
Apr 4, 2005 06:38 PM
incognito E46
Mar 19, 2005 03:27 AM
meanTheDope
Sep 23, 2004 08:08 AM
