TORQUE SPECS PLEASE......thanks need asap! im on hold
I have a b16a2 or the 2000si engine and tranny. I have the jun ultralight flywheel, and the jun clutch pressure plate, today i recieved the act performance street clutch disc and am trying to install it as we speek. I need to know the torque specs on the flywheel bolts. because i have no access to jun, or the person i purchesed it from, i was told to go with stock? Any other input? and if i do, i need to know what stock is for the flywheel bolts, im going with 35 ft.pds. on the pressure plate? quick need info fast. Thanks -eric
I'm looking at the Helms for a B17a. Should be the same for a B16a.
Flywheel bolts - 8 of them - 76 lb-ft.
Pressure Plate bolts - 9 of them - 19 lb-ft.
i agree, ill go with that unless someone can respond with the b16 manuel? Anyone with a act specs on the pressure plate? or an aftermarket flywheel? anyone else know if there is a difference?
thanks for the fast responce jasper_dbm
IMPORTANT: Put red locktite on the bolts for the flywheel -- TRUST ME. I didn't on one fly and the bolts backed out even though I torqued them to spec with a snapon trq wrench. I have heard of other people having the same problem. Use red locktight.
As for trq specs for the b16a flywheel,
Flywheel to crank: 76lbs
I also took a pic of the trq specs from the haynes I have for civics. My helms is for my accord ;p PM me if you want it, its only decently clear in full size.
t0p_sh0tta
Jun 9, 2014 10:35 AM
danthemang3
Jun 20, 2009 11:37 PM
