indiglo question?
i got a set of indiglo guages for my 93 civic ex about a yr. ago and tried to put them on but couldnt get the stock ones out? thought that maybe they go right on top of the stocks but wasnt sure. so, do they? and in the directions that came w/it, it said to wire it to the tail-light wire but where is the tail-light wire in the dash? please help if you can, i would really luv to put these on my car. thanks
They should just go right over. take off the 2 screws that hold your stock speedo/water/etc. and put the indiglo over and screw it back on.
Now sure about tapping it into the tail lights. Just tap it to your dimmer switch.
You can connect them into power from the cig lighter if you want also. There should be 3 wires going to it, look for the one that connects to the light that is right above the lighter. I put some in for a friend and connected there.
06Accord5SPD
Feb 22, 2016 03:10 PM
