Motor oil to do compression test?
Old Jul 21, 2004 | 04:25 PM
TypeR0186's Avatar
Default Motor oil to do compression test?
i understand if a cylinder is bad (psi) then you put a cap full of oil in it and try again, so what does the oil do? just a question thx
Old Jul 21, 2004 | 04:38 PM
markpaco's Avatar
Default Re: Motor oil to do compression test? (TypeR0186)
If the pressure goes up considerably, then you know that it is the piston rings and not the valves/guides.
The oil will coat the ring and provide a better seal which raises the compression.
Old Jul 21, 2004 | 05:11 PM
TypeR0186's Avatar
Default Re:
how much psi is considerably to much? becuz mine is 180 across the board. i just want to do this to see if all the rings are worn out. 180 seems still to low.
Old Jul 21, 2004 | 05:22 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Re: (TypeR0186)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR0186 &raquo;</TD></TR><TR><TD CLASS="quote">how much psi is considerably to much? becuz mine is 180 across the board. i just want to do this to see if all the rings are worn out. 180 seems still to low. </TD></TR></TABLE>
It depends on the gauge; if the gauge has a lot of volume before the 1-way valve, the measured compression will be lower. Test your gauge on another car to see if 180 psig is low.
Old Jul 21, 2004 | 05:41 PM
Racebrewer's Avatar
Default Re: Re: (Dogginator)
When you did your test was the motor warm and was the throttle open? A warm motor gives a higher and more realistic reading than a cold one.
John
Old Jul 21, 2004 | 07:03 PM
TypeR0186's Avatar
Default Re: Re: (Racebrewer)
the motor was warm and WOT, followed cspeed how to. my brothers gsr got 175psi across. im assuming the gauge is correct.
Old Jul 21, 2004 | 07:17 PM
Dogginator's Avatar
Daisy... Daisy...
Your compression should be fine, since it is consistent at 180 psig. Your gauge just reads low.
Old Jul 21, 2004 | 07:40 PM
Combustion Contraption's Avatar
Yeah, 180 is fine as long as all the cylinders are within 10 psi of each other.
lando griffin
Feb 12, 2008 10:39 PM
Fat Chick Magnet
Nov 22, 2006 09:52 PM
nekoabandoned
Jul 24, 2006 03:39 PM
vtec.dc2
Oct 26, 2005 07:19 PM
mafay2
Nov 11, 2004 07:34 PM
