whats the best Clutch and Flywheel setup?
Old Jul 21, 2004 | 02:09 PM
blueradii's Avatar
Default whats the best Clutch and Flywheel setup?
i want to get a good clutch that'll last a bit longer and with stands around 300 HP. also the flywheel i heard theres an 8.8 lb flywheel and the like a 12 lbs one, what the best kind of clutch and flywheel?
Old Jul 21, 2004 | 02:10 PM
blueradii's Avatar
Default Re: whats the best Clutch and Flywheel setup? (blueradii)
oh this is for a 99 prelude SH .
Old Jul 21, 2004 | 02:16 PM
specialedition's Avatar
yeah I would like to know that too I am having a jdm vtec put in and the shop is using exedy clutch (which is good) and a 8.8 lb flywheel made out of chromlium they said that the acceleration is awesome and that it can accerlate so fast that when you get off of it and slow down the car can stall which I do not know if it would cause damage or not but I have seen sites with vtec ludes running 10 sec or better 1000 ft times with similar setups
Old Jul 21, 2004 | 02:41 PM
Memo6453's Avatar
i hear the street lite Flywheel from ACT goes go0d with the heavy duty clutch. i think its like a stage 2.
http://www.modacar.com
Old Jul 21, 2004 | 04:22 PM
eLUDEnu
Guest
Posts: n/a
Default Re: whats the best Clutch and Flywheel setup? (Memo6453)
Fidanza 8.5 lb flywheel and ACT organic clutch. thats my 2 cents. any stronger of a clutch is gonna kill your leg
Old Jul 21, 2004 | 04:44 PM
Twiggz's Avatar
Default Re: whats the best Clutch and Flywheel setup? (eLUDEnu)
I also have a gen5. I've tried two clutches already.
when I just had bolt ons, I upgraded to Fidanza 8.5 lb flywheel and ACT HD clutch, with organic street disk.
the pedal feel in the car was only slightly more heavy then stock. after a day, I didn't even notice it. worked great till one of the springs broke off my disk.
many people had some trouble driving my car. it stalls really easy with that FW... but the added torque was great.
now I'm running the same Fidanza FW, with the ACT Xtreme pressure plate, and 6 puck disk.
car is really touchy, pedal is heavy now, but my leg does not get tired from it. my buddy had the same clutch in his teg, and that pedal is freakin heavy! also it does not like to start off to smooth at low speeds, it has some chatter (like rollin up in a drive thru line). but she launches like a dream!
so I suggest just going with the HD plate and street disk. it worked great for me... uhh except for the disk breaking lol
Modified by Twiggz at 6:25 PM 7/21/2004
b16a27
Nov 1, 2004 01:00 AM
honcrx91si
May 17, 2004 05:01 PM
Solipsist
Dec 6, 2002 11:49 AM
Hondasaurs
Mar 3, 2002 09:24 AM
