what cam for A6/ZC
Old Jul 21, 2004 | 02:00 PM
sporty240's Avatar
Default what cam for A6/ZC
which cam is should I get for my Sohc ZC?
I was looking at delta 260 or 272, and sr909 from exospeed...
btw I am going to go turbo/sc pretty soon, are these good with forced induction?
Old Jul 21, 2004 | 02:17 PM
civicflow's Avatar
Default Re: what cam for A6/ZC (sporty240)
If you are going turbo the stock cam might be better for driveability. A cam with bigger intake and exhaust lift might make the intake and exhaust timing overlap.
Just a thought.
Old Jul 21, 2004 | 04:51 PM
sporty240's Avatar
Default Re: what cam for A6/ZC (civicflow)
is anyone running these cams in their FI cars?
Old Jul 21, 2004 | 05:43 PM
HumanResource's Avatar
I know of someone running the SR909 in their JY Turbo D16 runs pretty good.
I personally have one in my N/A sohc ZC
Old Jul 21, 2004 | 07:16 PM
sporty240's Avatar
how muc whp are you guys putting down? 1/4 time? how is the low end on that cam?
Old Jul 21, 2004 | 09:41 PM
Jockobo's Avatar
i was running a crane stage 3 when i had a turbo d15...it def helps in the daily driving department(a lot more low/mid range torque) and i got the car down to 13.1s with it. i ran a delta with turbo and all i can say is...its a lot slower than the stock cam was...
Old Jul 21, 2004 | 10:26 PM
sporty240's Avatar
Default Re: what cam for A6/ZC (Jockobo)
which delta cam were you running with the turbo 260 or 272?
how much did the crane cam cost?
Modified by sporty240 at 7:43 AM 7/22/2004
Old Jul 21, 2004 | 10:42 PM
Full Race A6's Avatar
DELTA 272!!!!!!!
It ******* rocks. Ive got her in my stock A6. I used to have a bunch of comparisn charts for this cam along with the sr909 and the zex cam.
This cam by far (about 4-6whp across the band) blew both away. From 4400+ it pulled away.
I then researched buying one. CHEAP! Amazing power without the high price.
I guess its because they arent an established company or whatever but there **** kicks ***, they give you a few bucks for your stocker as well, covers shipping.
Ill see if I can find the charts
Old Jul 22, 2004 | 01:19 AM
Jockobo's Avatar
the crane goes for around 330. im not sure what the delta was...i doubt the delta would be good for turbo though...the crane is made specifically for turbo.
Old Jul 22, 2004 | 06:57 PM
sporty240's Avatar
ttt
Old Jul 22, 2004 | 08:56 PM
Default Re: what cam for A6/ZC (W O T)
SR909 cam vs. Delta 272 is not a fair match
Try the Stg III Race A6 cam and you'll change your mind
Old Jul 22, 2004 | 11:11 PM
sporty240's Avatar
hey wot have you gone to the track or dyno with that cam?
Old Jul 22, 2004 | 11:14 PM
ceLtic's Avatar
N/A wh0re!
sporty, where did you get your delta cam?
edit, not sporty....WOT. where did you get it? price?
Old Jul 23, 2004 | 11:17 AM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by W O T &raquo;</TD></TR><TR><TD CLASS="quote">DELTA 272!!!!!!!
Ill see if I can find the charts</TD></TR></TABLE>
couple of questions for you, where does the powerband come on? did it feel like you lost any low end power (not that there was much there anyway)? and are there any valvetrain mods required to run that specific cam?
Old Jul 23, 2004 | 01:59 PM
ceLtic's Avatar
N/A wh0re!
Default Re: what cam for A6/ZC (temp)
like springs and retainers....^^^?
Old Jul 23, 2004 | 03:22 PM
Default Re: what cam for A6/ZC (ceLtic)
They said it required no mods but they did say that most stage 2 or similar and up cams were putting a good deal of strain on the factory springs.
My head is pretty build up though, Dual Titanium springs, ferrera retainers, 1mm oversized titanium valves, delta 272, 3 angle valve job, port n polished, milled .040 for compression
$115 for the cam from a ht member
I couldnt tell you when the power starts just from the cam because everything was done at the same time. AND ITS AMAZING!
Soon to be mated with 11.5:1 compression pistons and forged rods and some nitrous.
Modified by W O T at 7:18 PM 7/23/2004
Old Jul 23, 2004 | 06:12 PM
sporty240's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ceLtic &raquo;</TD></TR><TR><TD CLASS="quote">sporty, where did you get your delta cam?
edit, not sporty....WOT. where did you get it? price? </TD></TR></TABLE>
you can get the cam from Delta Cams for $85 plus shipping there and back, the cams are a regrind of the stock one, the price is the same for the 260 and 272...
Old Jul 23, 2004 | 09:27 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ceLtic &raquo;</TD></TR><TR><TD CLASS="quote">like springs and retainers....^^^? </TD></TR></TABLE>
yes
Old Jul 23, 2004 | 09:28 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by W O T &raquo;</TD></TR><TR><TD CLASS="quote">They said it required no mods but they did say that most stage 2 or similar and up cams were putting a good deal of strain on the factory springs.
Modified by W O T at 7:18 PM 7/23/2004</TD></TR></TABLE>
ok so your head isnt stock, i guess i will just get their 260 cam then
Old Jul 28, 2004 | 12:01 PM
ceLtic's Avatar
N/A wh0re!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">
ok so your head isnt stock, i guess i will just get their 260 cam then</TD></TR></TABLE>
blah, its a regrind. i want another core...
mattie_96
Apr 2, 2006 01:22 PM
stevescivic
Sep 11, 2005 10:38 PM
rice is nice
May 31, 2005 09:12 AM
davens
Feb 6, 2004 07:21 AM
