still lost on multi-point swap
Old Jul 21, 2004 | 11:29 AM
CRseXxy's Avatar
Default still lost on multi-point swap
ok, for starters i will say everyone has been a help (dpfi to mpfi), and the links that ive looked at have been more than helpful... there is only one problem... every link that ive looked at say to switch the dx wiring harness to b16 engine... i dont have a dx harness, i got the car with no engine (90 dx) i do however have the si wiring harness and a b16a wiring harness.... from what ive read and seen, i know niether harness lines up.. should i get a dx engine wiring harness or should i modify the other wiring harnesses to plug in to the wiring harness on the car?
Old Jul 21, 2004 | 11:33 AM
520_Motorsports's Avatar
Default Re: still lost on multi-point swap (CRseXxy)
look on ebay all you need is a si cabin harness if you have the under hood harness. the cabin harness is located under the dash behind the glove box then you don't have to mess with anything else just get the vtec subharness from hasport it's like $75.00 shipped. Hope that helps
Old Jul 21, 2004 | 11:52 AM
92integra_gs's Avatar
first question what kind of engine are you planning to drop in.... i am not very clear, but under the impression that you will be getting a b16 engine...
there is no point of buying a dx wiring harness.. when you got an mpfi harnesses lying around... just modying both harnesses and make it fit... since you dont got a engine in it yet... this will make it easier for you to do this...
Old Jul 21, 2004 | 07:05 PM
delsold16's Avatar
well maybe if you werent such an idiot you wouldn't be lost on the multi point swap you idiot. and then you may be able to figure out why you keep helping your friend with his girlfriends stupid integra. and getting your dumb daily driver jeep out of swamps with no 4x4.
good luck dipsh*t!!!!
Old Jul 21, 2004 | 07:58 PM
93slmdcvcsi's Avatar
Default Re: (92integra_gs)
Well, to start off you will need a stock harness for that chasis, or some of the pins in the shock tower harness will not be the same. Take this from someone that has done it before!
Old Jul 21, 2004 | 08:31 PM
vtecn8ive's Avatar
Default Re: (89cvchb)
You should get a DX/lx/std (DPFI) and get it modified to MPFI/VTEC. That is if you still got the Engine harness (Shock tower to ECU). If you have no wiring at all then switch over to a complete MPFI wiring swap.
Old Jul 21, 2004 | 09:40 PM
CRseXxy's Avatar
Default Re: still lost on multi-point swap (delsold16)
"oh hey chris, make that left... u wont get stuck"
Old Jul 21, 2004 | 09:45 PM
CRseXxy's Avatar
i do have an engine, a b16a engine
Old Jul 22, 2004 | 08:07 PM
Default Re: (CRseXxy)
use the SI and b16 wiring harness and just modify the harness...
CRXCIVICMIX
Sep 13, 2005 10:01 PM
89-ef
Feb 25, 2004 06:42 PM
