Mini-me Swap question
Ok i am going to make this as short as i can, i searched and didn't have much help. I have a 96 Odb2a d16y7 motor and want to do a mini-me using a Y8 head, now my question is if use a obd2b head but i use a obd2a intake manifold and my stock dizzy(obd2a) will i need the jumper harness??? i know i also plan to run a p2p ecu, i know i have to change a few wires but other wise, can this be done without problems
dude there is a MASSIVE write up about this. next time really search. i searched for MINI ME and got this for ya.
https://honda-tech.com/zerothread?id=735196
Yeah i have read that 2, but thats not my question. in that write up they used a 96 odb2a head, which i know would work fine. my question is if i use a 99-00 y8 which is obd2b with all obd2a stuff will it work, i hope this makes it clear
well, since i cannot help you cause i am more of a b-series guy myself, i am sure someone such as bauley will be by soon to offer you some help. i would say PM bauleycivic for he is one of the mini-me guru's i know of on the board
a mini-me is using a d series vtec head on a non vtec block.
secondly, you should be able to use the obd2b head just fine as long as you use obd2a sensors (since im not sure if the plugs are different. i dont think that they are. i think that just the ecu plugs are different.)
So what you are saying is that as long as i use all of the same plugs and dizzy and stuff i should be good. when you say the ecu plugs are different i take it you mean between the obd2"a" and "b". now i want to use the Obd2a ecu(p2p) i think it should work but i just wanted to dubble check. Any other info would be greatly excepted, also if you have done this beofer let me know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaciv3 »</TD></TR><TR><TD CLASS="quote">well that basicly answers all of my question, and who ever made that write up you did one hell of a job</TD></TR></TABLE>
Thank katman https://honda-tech.com/zero...id=26
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fuckecheck »</TD></TR><TR><TD CLASS="quote">I'm pretty sure u have to match the ecu to the head, so u would need a 99-00 EX ecu with the 99-00 EX head</TD></TR></TABLE>
Uh no, you match the ecu and distributor to the car year.
Mini me on 92-95: p28 ecu and obd1 dizzy
Mini me on 96-98: 96-98 p2p ecu and 96-98 dizzy
Mini me on 99-00: 99-00 p2p ecu and 99-00 dizzy
