Semi-Pointless Post: Y80 gearbox weight vs. J1 gearbox weight
Old Jul 21, 2004 | 09:11 AM
Driven's Avatar
Default Semi-Pointless Post: Y80 gearbox weight vs. J1 gearbox weight
For those curious:
Y80 - 85lbs
J1 - 84lbs
I weighed the two hoping that the increased weight of a B18C1 vs a B16A1 was largely due to the hydro gearbox.
nope. It seems to be that the B18C1 weighs roughly 9lbs more than a B16A1.
i tried to weigh the engines, but, a bathroom scale is tough to see the weight when an engine is placed on top... but, with a ROUGH estimate, the GSR weighs around 210lbs, minus gearbox/flywheel.
Modified by Driven at 12:10 PM 7/21/2004
Old Jul 21, 2004 | 09:17 AM
EL Vap133's Avatar
Default Re: Semi-Pointless Post: Y80 gearbox weight vs. J1 gearbox weight (Driven)
Good to know.
Old Jul 21, 2004 | 09:26 AM
Rywire's Avatar
Default Re: Semi-Pointless Post: Y80 gearbox weight vs. J1 gearbox weight (EL Vap133)
Well, one thing I can add is that gsr intake manifold is much heavier than the b16a.
Old Jul 21, 2004 | 11:10 AM
Driven's Avatar
edit, GSR is 9lbs more than B16, not 60lbs.
I have no clue where I got 60lbs though.
Old Jul 21, 2004 | 11:26 AM
Rywire's Avatar
HAHA, good, I was questioning that too. PHEW. Ryan
PS, the IM is heavier, and the deck height being like 7mm higher adds a hair.
Old Jul 21, 2004 | 11:35 AM
Fred.Rodgers's Avatar
9pounds!!!! that's it???!?!? where are all those people telling me that the -18 is so much heavier that it will throw my suspension setup out of wack. damnit.
someone weigh a b16 and a h22. with trannys (the non eggy type)
if they are anywhere close, my swap is gonna change.
Old Jul 21, 2004 | 01:59 PM
Driven's Avatar
Default Re: Semi-Pointless Post: Y80 gearbox weight vs. J1 gearbox weight (Transptr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Transptr &raquo;</TD></TR><TR><TD CLASS="quote">9pounds!!!! that's it???!?!? where are all those people telling me that the -18 is so much heavier that it will throw my suspension setup out of wack. damnit. </TD></TR></TABLE>
depends... I pulled my figures from a website for engine weights.
although only .003% of the car's weight, 9lbs eventually will add up when you keep adding stuff.
sshaikh01
Jul 27, 2006 11:07 AM
combustion
Nov 17, 2003 08:54 AM
x James Bond x
Jul 18, 2002 05:15 PM
gsr98vtec
Jul 16, 2002 07:35 PM
Flux
Jun 20, 2001 06:44 PM
