do i have to re-wire?? when..
okay, i find out some weird syndrom of my car.. and i think it have something to do with the wires under my hood..
1. first of all, my inmobilizer occationally didnt work for some reason, the blue light is gone, means not armed, i need to turn on and off 3 times to re-arm it..(and into automatically arm mode, armed in 15 sec after igniton is out )
2. from (1)..i can just use a big L-shape ruler.. slide in from the window and hook the door lock switch up and open the door..when no alarm siren..means disarmed totally.
3. When outside weather is hot.. i mean over 35 degree C., the remote control didnt work for some reason(only happen occationally). then i need to use method in (2) to open the door..when i dont usually have a big ruler with me.
4. finally, today im driving on the highway. 2 of the light blub brunt in a suddent.. 1 is normal.. 2 at the exact same time is weird. and the fuse are ok after chking with it..just 2 blunt blubs.
so why that happen? i chk under the hood and find out there is a lot of places.. the wires have beem cut before, and re-connected with home-made method, such as cuting both end, and re-wire them by using those black tape. and some of the plug(i.e from the dizzy) , the wires are actually exposed in the air, means off the plastic plug.
will it be the reason that my electrical stuff gone crazy? but other then that my car is totally in normal condition..
any imputs are welcome. thanks
Laz.
Modified by sinister6 at 6:15 PM 7/21/2004
Laz.
shermanyang
Honda CR-V & Element
Sep 8, 2012 06:20 PM
OEM Man
Oct 19, 2007 03:27 AM
OEM Man
Audio / Security / Video
Aug 22, 2007 06:21 AM
