LSD talk, fitment and differences
Old Jul 21, 2004 | 08:36 AM
Bseriesy0's Avatar
Default LSD talk, fitment and differences
First question, would a Quaife Differential fit in any Kseries tranny(A2 or A3) or would there be some modifications involved? Second, whats the difference between the Quaife and CTR or ITR LSD? TIA.
Old Jul 21, 2004 | 09:19 AM
A032R's Avatar
Default Re: LSD talk, fitment and differences (Bseriesy0)
I have Spoon 1.5 Way LSD installed on my K20A2, you will need the DC5R final gear to install LSD.
I'm guessing that the Quaife would be a better pick then the DC5R LSD , both are helical (require less maintanence then a clutch type) , as long as you can throttle while you exit corner w/o inside wheel spin i guess it does its purpose
Old Jul 21, 2004 | 09:25 AM
Bseriesy0's Avatar
Default Re: LSD talk, fitment and differences (A032R)
Thanks for the info, so I need the final drive for the Quaife or ITR install? Can anyone confirm this? I read a thread just now (doing research) and someone installed an ITR LSD and he did not mention the final drive.
Old Jul 21, 2004 | 05:58 PM
Kal's Avatar
Kal
Quaife is good. It is a Torsen type LSD. So far, I heard that there is not a need to switch FD to fit the LSD into the tranny. I would suspect the Spoon piece needs the ITR FD, because Spoon caters to the K20A more than they do to the K20A2...which has a lower FD.
Old Jul 22, 2004 | 12:33 AM
RsxVengeance's Avatar
you don't need the FD, people do them in the same time to save the trouble from doing it later.
ekcivic2
Transmission & Drivetrain
Jun 1, 2014 03:29 PM
Wh0 Iz UNREAL07
Nov 11, 2010 09:42 AM
shadowz
Apr 11, 2004 08:59 AM
turbo Si
Mar 15, 2003 07:00 PM
ILOVEGIRLS
Oct 10, 2002 01:56 AM
