FYI: for all those with speedometer problems
Old Jul 21, 2004 | 06:05 AM
Accordloser's Avatar
Default FYI: for all those with speedometer problems
In dealing with my own speedometer problems (1994 accord EX, 5 spd MT), I've ran into several others with similar problems (speedometer jumps slowly from 0-25 (or so) at low speed, increasing it's jumping as speed is increased and finally settling out at around 20 mph at higher speeds - on occassion, it decides to work). I thought a little explanation of symptoms may clear up some of the confusion I had when first dealing with the problem...
1) Your VSS is the problem when...
a) your speedometer / odometer / cruise control go out.
b) your check engine light comes on (code 17 is the VSS)
2) Your VSS is not the problem (and you probably need a new speedometer) if...
a) your speedometer / odometer stop working, but the cruise control still works
b) there is no check engine light
Hope this helps someone avoid some of the costs of trying to fix something that's not broken.... or to even save some time in trying to diagnose the problem.
Old Jul 21, 2004 | 05:13 PM
Schmitey's Avatar
Default Re: FYI: for all those with speedometer problems (Accordloser)
thanks for the info! That could have saved my friend some money. I didn't know if her accord was run off a cable or what, and she was from out of town so I didn't want to get involved. Cost her like $300 and I'm sure all they did was replace the VSS.
psm321
Nov 27, 2018 03:13 PM
civicSF98
10
Aug 30, 2009 05:10 PM
jerry5150
Apr 20, 2009 06:31 PM
96electronH
Feb 3, 2008 05:17 PM
pat671
Nov 12, 2006 08:01 PM
