Build Up the Top Or Bottom End First?
Old Jul 21, 2004 | 05:48 AM
95VXB16A's Avatar
Default Build Up the Top Or Bottom End First?
My setup is 93 B16a Sir2- Aem cai, Jdm Dc 4-1, 2.5 Exhaust, Hi-flow cat, skunk2 P28, Y21 trans + act stage2 clutch. I have about $1800 to spend, for the top-end I want to run ITR cams, valve springs, skunk2 gears, mugen gasket, mild p&p. For the bottom-end I want to run a 94-95 B18c1 block with Jdm ITR pistons, arp studs botls, new oem bearings, oil pump etc… TIA
Old Jul 21, 2004 | 07:26 AM
respectblades's Avatar
Default Re: (Rob Deal)
build the bottom end first ....
you'll need more than 1800$ for that though
Old Jul 21, 2004 | 09:28 AM
RayB's Avatar
I agree. I'd build the bottom first.
Old Jul 21, 2004 | 10:15 AM
chad174's Avatar
Default Re: (RayB)
Why go to forged pistons when he can just go with the quality and reliability of an OEM piston, for cheaper, as it seems that he is on a budget and probably has price in mind? He's already gonna have as high of compression as he will need to make good power that that setup. Build the bottom first IMO.
Old Jul 21, 2004 | 05:32 PM
95VXB16A's Avatar
Default Re: (respectblades)
I called up a shop in Glendora today. They can do a full LS-Vtec swap with Jdm Itr pistons, arp studs and bolts, all new bearings, all new seals, labor, and the block for $2200. Is this a good deal? How much reliability would I lose if I went with an ls-vtec setup vs a Poor Man’s ITR setup?
Old Jul 21, 2004 | 07:59 PM
Default Re: (95VXB16A)
<FONT COLOR="red"> a neecher hit up the homie SnoFlake EG &lt;--- you know the story haha juss hit him up and get some ideas ..</FONT>
Old Jul 21, 2004 | 08:04 PM
zad5's Avatar
resleeve the b16 2.0 and buy some pistons. you mite have money left over for some cams. but the gsr block thing isnt too bad of an idea either.
st9vex
64
Jun 5, 2012 08:11 AM
codyellis
Feb 28, 2008 02:02 AM
da4sale
16
Aug 21, 2007 09:28 PM
JDM_EK_JOE
May 18, 2006 12:17 PM
Eluzion
May 10, 2004 06:45 PM
