K and B series clutch compatibility?
Old Jul 21, 2004 | 12:02 AM
Blazeone's Avatar
Default K and B series clutch compatibility?
I have a extra k20 exedy disk leftover from my k series clutch that i never did, i compared it with my stock clutch disk, it has the same diameter, depth, input shaft diamter. I bolted it up, but i was wondering if there is anything that could possibly go wrong, since it is for a k series? But it bolts up absolutely fine no problems. The only physical difference between them by the looks of it is that the exedy is a dual spring disk, with larger fibres in it.
I was running a spoon flywheel, spoon organic disk, spoon pressure plate.
Old Jul 21, 2004 | 12:45 PM
Blazeone's Avatar
Default Re: K and B series clutch compatibility? (BlazeONE)
good or bad idea?
Old Jul 21, 2004 | 03:53 PM
white rocket's Avatar
As hokey as this info is, I read in a mag that a guy put a Type R clutch is his RSX(K motor I think). So that worked, as for the other way around, I dunno. Hows that for some hear-say.!!
Kamin
Apr 11, 2002 06:18 AM
