Can EG suspension fit on 94+ teg?
Old Jul 20, 2004 | 11:18 PM
Hatchbizzack's Avatar
Default Can EG suspension fit on 94+ teg?
I thought I had read somewhere that suspension off a 92-95 civic was interchangeable with a 94+ integra. I wanted to know before I sold my shell this week with the suspension because I plan on getting an Integra next.
Parts are Tokico Illumina 5 way struts and Vis Coilovers if it makes a difference.
Old Jul 20, 2004 | 11:22 PM
frostcivic's Avatar
Default Re: Can EG suspension fit on 94+ teg? (Hatchbizzack)
i know they use some integra rear trailing arms to convert eg civics to rear wheel discs, but you gotta be more specific though.
Old Jul 20, 2004 | 11:25 PM
rodrez.'s Avatar
So you want to put the Civic's shocks/springs on the new Integra you're getting? Are you sure you'd want to run Civic spring rates in an Integra chasis?
Old Jul 20, 2004 | 11:26 PM
Default Re: Can EG suspension fit on 94+ teg? (frostcivic)
Basically, I just want to know whether or not I can take my struts and coilovers off my 92 Si hatch and install them on a 94+ integra.
I am going to eventually upgrade to a set of Skunk 2 Coilovers, but I just wanted to know if I could do it makeshift for a couple of weeks.
Old Jul 20, 2004 | 11:52 PM
mikehawkBUiLT's Avatar
im sure this is covered 23984298398 times that 92-95 civics and 94-01 integra's can use the same suspension meaning they're interchangable period.
Old Jul 21, 2004 | 12:07 AM
civtegra_hybrid's Avatar
yeah you deff. can use your civic suspension on your integ. you can even swap all the lower control arms, and the upper A arms, your camber kits, the lay out is the same, alot of pepl. swap all the integ. susp. to there civics to get the 10" brakes in the front and rear disc in the back, also they swap the front and rear lower control arms so they can use sway bars, (some civic's don't have the holes on the control arms to put the bolts for the sway bars) so when it comes down to it the whole suspen. is interchangeable.
Old Jul 21, 2004 | 01:37 AM
Default Re: (EJcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJcoupe &raquo;</TD></TR><TR><TD CLASS="quote">im sure this is covered 23984298398 times that 92-95 civics and 94-01 integra's can use the same suspension meaning they're interchangable period.</TD></TR></TABLE>
Good thing there are always people like you to contribute all they can to threads where people actually help other people.
Get a life, and please don't waste the rest of our time.
thanks to anyone that gave me helpful information.
Old Jul 21, 2004 | 02:40 AM
AzntaggeR's Avatar
TSPeed Factory
yes they are interchangeable , and yes this topic has been beaten to death and then some.
Old Jul 21, 2004 | 12:47 PM
Default Re: (Hatchbizzack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatchbizzack &raquo;</TD></TR><TR><TD CLASS="quote">
thanks to anyone that gave me helpful information.</TD></TR></TABLE>
does that not help you? i believe that answers your question, does it not? also, read between the lines, SEARCH YOU NOOB. by not doing so, you're the one thats wasting our time
Old Jul 21, 2004 | 12:51 PM
SolObsession's Avatar
Most people with swaps get integra spring rates for their civic....not so sure I would want to run an integra with civic spring rates. But yeah, it will swap.
Old Jul 21, 2004 | 12:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJcoupe &raquo;</TD></TR><TR><TD CLASS="quote">does that not help you? i believe that answers your question, does it not? also, read between the lines, SEARCH YOU NOOB. by not doing so, you're the one thats wasting our time </TD></TR></TABLE>
&lt;---- Can you not read? I have been registered here 10 more months than you and have been posting the entire time! Quit ******* trying to fit in with everyone else here you waste of space.
Go away, and commit suicide or something useful with your life.
Old Jul 21, 2004 | 01:24 PM
actually you dumb ****, im frosteg6 also which means ive been a member longer than you and you're still a noob cause you've been a member for 10 months and still dont know if eg shocks fit on dc's. idiot.
Old Jul 21, 2004 | 01:27 PM
ichiban00's Avatar
Just out of curiousity, if these were stock civic springs ur putting on ur teg, would it sit a lot lower than on stock teg springs due to diffeneces in vehicle weight? and vice versa (ie: civic will sit higher on stock teg springs)??
I'm asking cuz my stock civic springs are damaged and I was gonna put some teg springs on to pass inspection (I have H&R's coming in a week or two)
Old Jul 21, 2004 | 02:06 PM
rodrez.'s Avatar
Default Re: Can EG suspension fit on 94+ teg? (ichiban00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ichiban00 &raquo;</TD></TR><TR><TD CLASS="quote">Just out of curiousity, if these were stock civic springs ur putting on ur teg, would it sit a lot lower than on stock teg springs due to diffeneces in vehicle weight? and vice versa (ie: civic will sit higher on stock teg springs)??
I'm asking cuz my stock civic springs are damaged and I was gonna put some teg springs on to pass inspection (I have H&R's coming in a week or two)</TD></TR></TABLE>
Yes, the Integra will sit lower with Civic springs, and the Civic will be 4x4 status with Integra springs.
Old Jul 21, 2004 | 11:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJcoupe &raquo;</TD></TR><TR><TD CLASS="quote">actually you dumb ****, im frosteg6 also which means ive been a member longer than you and you're still a noob cause you've been a member for 10 months and still dont know if eg shocks fit on dc's. idiot.</TD></TR></TABLE>
Registration date: 6-19-2003
Today's date: 7-22-04
Learn how to count you juvenile imbicile. Grow up and move on, this has got to be the pettiest argument I have ever even had to involve myself in. I didn't ask because I didn't know, I asked because I wanted to make sure.
Bye.
Old Jul 22, 2004 | 12:13 AM
ARIZONA's Avatar
Boys boys... MOOve on... this is a tech forum... not an arena.
Old Jul 22, 2004 | 12:15 AM
Bruce Leeroy's Avatar
Default ?
if you don't have nothing nice to say or helpful, then don't say it at all, it only makes you look more stupid.
Old Jul 22, 2004 | 11:26 AM
Default Re: ? (JDM_IS_GAY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_IS_GAY &raquo;</TD></TR><TR><TD CLASS="quote">if you don't have nothing nice to say or helpful, then don't say it at all, it only makes you look more stupid.</TD></TR></TABLE>
yea, you're right, what a complete ******* i am. sorry you got all butthurt and defensive from my original post (on the INTERNET i might add), "hatchbizzack" . next time, dont take it to the heart uhkay?
Old Jul 22, 2004 | 09:31 PM
Default Re: ? (EJcoupe)
it's okay, don't let it happen again
gtec8285
Oct 6, 2006 06:46 PM
hatch_
Suspension & Brakes
Jan 29, 2006 06:47 PM
Mikizzle
Oct 25, 2004 09:01 PM
Norcalstoppy
Jun 24, 2003 12:16 AM
