Factory Alarm System Keeps going off
Old Jul 20, 2004 | 09:56 PM
Johnson's Avatar
Default Factory Alarm System Keeps going off
I have a 1999 Honda Civic with a factory alarm system. For some reason the alarm goes off at all hours of the day. After the alarm goes off, I check around the car and there are no signs of forced entry or any type of glass breakage sounds that would cause the car to react. The only thing that might be causing the problem is the variation in temperature or moisture. It seems very intermittent. Any suggestions would help. Thanks.
Old Jul 20, 2004 | 09:58 PM
ridiculous's Avatar
Default Re: Factory Alarm System Keeps going off (Johnson)
never heard of an alarm going off because of temperature difference, maybe there is a short? bad battery? i know your car is pretty new, but you never know...
good luck!!
Old Jul 20, 2004 | 10:14 PM
ComingSoonNearYou's Avatar
Default Re: Factory Alarm System Keeps going off (ridiculous)
I think you would get more replies if you post this in the Audio / Security / Video section
Old Jul 20, 2004 | 10:47 PM
2000CTRSi's Avatar
the battery fuse went bad
Lucero
May 8, 2017 10:04 PM
SPEED123
Jun 26, 2011 12:20 AM
pdd
Honda Civic (2001 - 2005)
Jul 28, 2007 09:50 AM
dukers
Jul 18, 2005 05:39 PM
makeshift
Mar 10, 2005 08:11 PM
