is there an obd0 vtec ecu and dizzy?
Old Jul 20, 2004 | 09:00 PM
4door93civic's Avatar
Default is there an obd0 vtec ecu and dizzy?
i am thinking about doing a mini me swap into my 91 si but would i have to get an obd0 to obd 1 harness? because if i do this i will be using a z6 head. thanx.
Old Jul 20, 2004 | 09:15 PM
crxgator's Avatar
Default Re: is there an obd0 vtec ecu and dizzy? (4door93civic)
you can modify the a6 distributor to work with the Z6 head, or get a y8 head and it will bolt right up...
as far as ecu, well pm6, pg7 with a vtec controllor, or a zdyne one wire ecu...
Old Jul 21, 2004 | 12:16 AM
dragsource hatch's Avatar
Default Re: is there an obd0 vtec ecu and dizzy? (crxgator ESQ.)
if you are interested, i make some brackets so the obd0 dizzy will work correctly with the z6 head without cutting the dizzy and still having the ability for adjust timing. If you are interested, send me a pm.
thisxlaosxguy
Apr 23, 2013 05:49 PM
EFstyle
15
Apr 19, 2008 05:02 PM
#Leo#
Feb 4, 2008 08:43 PM
Mr_Moos
Mar 30, 2007 10:07 PM
