Stumbling Accord!
Old Jul 20, 2004 | 08:27 PM
LCalzadilla's Avatar
Default Stumbling Accord!
My 91 Honda Accord EX coupe (automatic) with 170K has begun to run rough between 1500-2000 RPM under load.
I first thought it was a bad cap & rotor so I gave it a full tune up (new NGK plugs, rotor, cap, fuel & air filter, oil change and checked timing), problem continued.
I thought maybe it was the o2 sensor so I replaced it, problem continued.
I checked the ECU for codes and 12 was displayed although check engine light is not illuminated.
I checked the EGR and it seems to be operating correctly but I still replaced, no change. (Note: I used salvage part, looked new)
I then changed the purge cut off solenoid, EGR control solenoid and constant vacuum control (CVC) valve. NO CHANGE! (Note: same as above)
PLEASE HELP!
Crushgroove
Sep 4, 2015 04:28 PM
Ju664l0
Jun 17, 2010 04:15 PM
1992_accord
Nov 13, 2007 03:21 PM
RAYThOM
Sep 3, 2005 07:12 PM
LCalzadilla
Jul 22, 2004 11:48 PM
