Cold air intake and exhaust
rumor has it that cold air intakes saves gas?? true or false? Details?
Rumor has it that exhaust waste gas? true or false? how??
Let the rumors become facts!!!
It is a possibility that cold air in takes do save gas because your freeing up the air from that stock restrictive box that makes the car suck harder. Also anytime you add performance parts your car performs better runs faster there for uses more gas so the exhaust things whole purpose technically is to waste gas burnt gas that is hehe!
both should save gas, if you drive normally, because they both free up restrictions that otherwise would cause the engine to work 'harder' (ever so slightly).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by obd2gsr »</TD></TR><TR><TD CLASS="quote">both should save gas, if you drive normally, because they both free up restrictions that otherwise would cause the engine to work 'harder' (ever so slightly).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by obd2gsr »</TD></TR><TR><TD CLASS="quote">both should save gas, if you drive normally, because they both free up restrictions that otherwise would cause the engine to work 'harder' (ever so slightly). </TD></TR></TABLE>
Added my exhaust but it feels like its wasteing more gas
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hyperazn108 »</TD></TR><TR><TD CLASS="quote">
Maybe you drive faster with the exhaust than without?
</TD></TR></TABLE>Maybe you drive faster with the exhaust than without?
air intakes systems let more air flow in than what the car is originally programed for and a less restrictive, higher flowing exhaust definitely lets out more exhaust (unless you just hacked off the muffler). When you have twice as much air going in and twice as much exhaust flowing out, you will need twice as much fuel and spark to compensate for the new, less restrictive set-up.
so the answer is false for the first question and true for the second. The only way to save gas with the air intake system is to install a K 'n' N drop in filter.
YNG
13
Aug 31, 2008 05:45 AM
CoolRedXylophone
Apr 30, 2006 08:15 AM
