Honda MTF vs. GM Syncromesh
Old Jul 20, 2004 | 06:17 PM
wreckedmyteg's Avatar
Default Honda MTF vs. GM Syncromesh
Choose your preferred weapon...for a high milage GSR transmission (100k), that will take a beating
Old Jul 20, 2004 | 06:21 PM
Stripped Honda's Avatar
99-0104
Default Re: Honda MTF vs. GM Syncromesh (wreckedmyteg)
regular 10W30 does the trick for me never had a problem with it
Old Jul 20, 2004 | 06:22 PM
Default Re: Honda MTF vs. GM Syncromesh (Stripped Honda)
running Castrol GTX 10w-40 and I'm getting glitter...
Time to switch.
Old Jul 20, 2004 | 06:29 PM
RacerXintegra2k's Avatar
i put redline in mine and loved it. much smoother.
Old Jul 20, 2004 | 06:36 PM
Muckman's Avatar
Moderator in Chief
Ive used all 3 and I prefer GM MTF and use it in all 3 of my cars.
Old Jul 20, 2004 | 06:40 PM
patdemps's Avatar
Default Re: Honda MTF vs. GM Syncromesh (Muckman)
GM syncromesh.
Old Jul 20, 2004 | 09:03 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I got GM Synchromesh friction modified for about $5/qt thru my friend at a dealer.
If you want it for alot cheaper than dealer price, use the Pennzoil Synchromesh sold at AutoZone and other auto parts stores. It runs about $4/qt I think.
Old Jul 20, 2004 | 09:05 PM
.water's Avatar
i heard lots of good things about redline..and mix with honda MTF and GM...how much is honda one and redline?
Old Jul 20, 2004 | 09:07 PM
shermanyang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Ive used all 3 and I prefer GM MTF and use it in all 3 of my cars.</TD></TR></TABLE>
yup...what Muckman said.
it's a whole lot cheaper if you buy Pennzoil Syncromesh which is what GM Syncromesh is without the GM badge. i got like 12 quarts of this stuff for like $3.75 each at autozone.
Old Jul 20, 2004 | 10:54 PM
Cliffjumper2's Avatar
Default Re: Honda MTF vs. GM Syncromesh (shermanyang)
I went to an acura dealer the other day, and the service/parts guy just condescendingly said, "stop banging on your gears". I told him, "you didn't answer my question". He replied, "no we don't have anything like that".
Then i went looking for the pennzoil syncromesh, but no luck there either.....went to pep boys, auto zone, R&S Strauss
anyone know a place in ny I can get this stuff.........I'm going to try a gm dealer tomorrow.
Old Jul 20, 2004 | 11:44 PM
cheezthis's Avatar
Default Re: Honda MTF vs. GM Syncromesh (DCcliffjumper2)
I use honda mtf...had used redline in the past. I actually didn't like it all. Grinds went away when changing back to mtf. I refuse to use GM's.
Old Jul 21, 2004 | 06:42 AM
ebelp's Avatar
Default Re: Honda MTF vs. GM Syncromesh (cheezthis)
GM Synchromesh with the FM additive is $12.50/qt. at the dealer here!
Old Jul 21, 2004 | 08:10 AM
furious94ls's Avatar
Default Re: Honda MTF vs. GM Syncromesh (ebelp)
HOnda MTF for good transmissons that are take care of.
Syncromesh for beat up trannies that grind and need a bandaid before getting rebuilt.
Old Jul 21, 2004 | 09:48 AM
Default Re: Honda MTF vs. GM Syncromesh (furious94ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by furious94ls &raquo;</TD></TR><TR><TD CLASS="quote">Syncromesh for beat up trannies that grind and need a bandaid before getting rebuilt.</TD></TR></TABLE>
Is that because it's a heavier weight, and it makes things seem like they are ok for a little while?
Old Jul 21, 2004 | 11:05 AM
TodaSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DCcliffjumper2 &raquo;</TD></TR><TR><TD CLASS="quote">
Is that because it's a heavier weight, and it makes things seem like they are ok for a little while?</TD></TR></TABLE>
No, it's just much better stuff.
I shied away from the GM synchromesh for years, then I tried it, now it's going in all my Hondas
Stuff is great.
Old Jul 21, 2004 | 12:05 PM
obd2gsr's Avatar
Default Re: Honda MTF vs. GM Syncromesh (TodaSi)
after i went GM synchromesh FM, i'm never using anything else
Old Jul 21, 2004 | 12:11 PM
b00sted4dr's Avatar
Default Re: Honda MTF vs. GM Syncromesh (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">I got GM Synchromesh friction modified for about $5/qt thru my friend at a dealer.
If you want it for alot cheaper than dealer price, use the Pennzoil Synchromesh sold at AutoZone and other auto parts stores. It runs about $4/qt I think.</TD></TR></TABLE>
Is the pennziol synchromesh the same as the GM synchromesh?? Im always seeing it compared between the two.
Old Jul 21, 2004 | 12:28 PM
obd2gsr's Avatar
Default Re: Honda MTF vs. GM Syncromesh (96gsr4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96gsr4dr &raquo;</TD></TR><TR><TD CLASS="quote">
Is the pennziol synchromesh the same as the GM synchromesh?? Im always seeing it compared between the two. </TD></TR></TABLE>
yes. so is ac delco synchromesh, but that's almost impossible to find
Old Jul 21, 2004 | 02:47 PM
CA6VTEC's Avatar
<FONT COLOR="royalblue"> I have JDM B16 ( Y1 ) and it's grinds 3rd & 4th on high rpms.. How well does that GM syncromesh work w/ the LSD? </FONT>
Old Jul 21, 2004 | 03:16 PM
EL Vap133's Avatar
$10 per quart of GM Syncromesh? I paid a little less than $7 per quart.
Old Jul 21, 2004 | 03:18 PM
EL Vap133's Avatar
Default Re: (CA6VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CA6VTEC &raquo;</TD></TR><TR><TD CLASS="quote"><FONT COLOR="royalblue"> I have JDM B16 ( Y1 ) and it's grinds 3rd & 4th on high rpms.. How well does that GM syncromesh work w/ the LSD? </FONT></TD></TR></TABLE>
Works great, my friend took my old Y LSD cable tranny that grinded bad in 3rd, added the Syncromesh and no more grinds.
Old Jul 21, 2004 | 03:19 PM
iH8RICERZ's Avatar
Default Re: (EL Vap133)
ive tried both....honda mtf, redline mtl, and gm synchromesh............i personally have liked the synchromesh out of all of them!
Old Jul 21, 2004 | 03:32 PM
B2FiNiTY's Avatar
Default Re: (iH8RICERZ)
You guys need to try syncromesh modified and not the regular stuff!!
Old Jul 21, 2004 | 03:37 PM
TodaSi's Avatar
Default Re: (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">You guys need to try syncromesh modified and not the regular stuff!!</TD></TR></TABLE>
That's what I use with my KAAZ LSD
Works great!
Old Jul 21, 2004 | 03:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TodaSi &raquo;</TD></TR><TR><TD CLASS="quote">
Stuff is great.</TD></TR></TABLE>
looks like I'm going to give that GM syncromesh a try
