b20 for the rex
Old Jul 20, 2004 | 04:24 PM
Slo Honda Driver's Avatar
Default b20 for the rex
is a b20 a good motor for the crx because i have one that i was gonna put into it and build up and possibly turbo but i was told to have it sleaved befor i turbo it
Old Jul 20, 2004 | 04:29 PM
Jurassic Four's Avatar
From: Where you cant steal it, Maryland, United States
Default Re: b20 for the rex (vtecwat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecwat &raquo;</TD></TR><TR><TD CLASS="quote">is a b20 a good motor for the crx because i have one that i was gonna put into it and build up and possibly turbo but i was told to have it sleaved befor i turbo it</TD></TR></TABLE>
If you were going to build it up: wouldn't you sleeve it anyway? But, the answer is: yes. If you plan on running in the upper RPM, or any substatial boost. You will at least need a block guard.
I read that some company makes sleves the resist to movement. Because that is the biggest problem. LA Sleeve maybe??? Maybe.
Old Jul 20, 2004 | 07:00 PM
africanqueen's Avatar
Default Re: b20 for the rex (Jurassic Four)
B20 will haul *** in a CR-X. Going to be VTEC'd? Yes, it will fit in your car with the proper mounts, shift linkage etc... Anywayz, let us know how the build up is going when you start on it.
Old Jul 21, 2004 | 11:20 AM
Default Re: b20 for the rex (mrspeaker)
coolcool thanxz guys i need to come across a tranny then i can put it in but ill keep everyone posted with whats going on ohh a b20 is a none vtec right i dont know a whole lot about them yet so just wanderin im sure its not is there a way to make it vtec or not
Old Jul 21, 2004 | 04:54 PM
anyone else got any suggestions about the b20 swap hit me up let me know thanxz guys
raceline test and tuned mother approved
http://www.racelinetuning.com
Old Jul 21, 2004 | 07:59 PM
Dwight Schrute's Avatar
if ur going to sleeve it anyway , why not get a ls block and bore it out?
Old Jul 21, 2004 | 11:31 PM
hahagasdcrx's Avatar
Default Re: b20 for the rex (drewthomas14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drewthomas14 &raquo;</TD></TR><TR><TD CLASS="quote">if ur going to sleeve it anyway , why not get a ls block and bore it out?</TD></TR></TABLE>
Because he said he already had the B20.
Good luck...
95 RED CIVIC
May 3, 2006 05:01 AM
T"u"Rtle
Sep 30, 2005 08:24 AM
JDMlyfestyle
Jan 9, 2004 11:24 PM
The G2 Racer
Nov 6, 2002 03:27 AM
