B16a Turbo, starts but stumbles and doesnt idle
Ok, i just finished my b16a turbo, turn it over with out touching the pedal, it starts runs a 2k then dies. If i give it one third throttle it will run but the rpms go from 2k to 2.5k over and over. IF i let it die its harder to start again.
Things i know
1.) Spark wires are in the right order.
2.) Cams and crank pully line up with TDC
3.) Im running TE with 450s dsm, i tried to lean it out or richen it up with my vfac and no change. I have gas (45 psi), i got only one CEL for ELD (maybe i need better grounds?)
4.) I cant do the ignition timing because i cant get it to stay running but tis the same wiht the dizzy all the way foward, back and in the middle
Any ideas?
Things i know
Any ideas?
ah a couple things that come to mind for me are;
-what shape are your injectors in? they might need to be cleaned. i had the same kind of problem with my ls/vtec. would start rev up to 2.5/3k then die.
-is your IAVC clogged or plugged?
-TE basemap is messed?
you have probably tried a few of these, just thought i'd see how it was going for you. goodluck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speeddave »</TD></TR><TR><TD CLASS="quote">ah a couple things that come to mind for me are;
the injectors havent been cleaned but hte car seems to be rich and can rev to 8k no problems, the iavc (on the tb right) i cleaned before i through on the tb (gsr)
nope the iavc should be on the back of your intake manifold, it has two coolant lines going to it, however i dont know if that would cause you that much trouble.
have you figured anything more out?
it was the bin i was running, i tried the afc hack wiht m pr3 and it ran fine then i burned the new gn30 bing and bam! it works
dylicious_eg6
51
Jul 28, 2015 08:11 AM
Boosted Chemist
Jul 21, 2004 02:12 AM
