car wont start when warm
hey guys, my b16a1 90 EF has been having problems lately with starting after being parked in the sun all day @ work. It'll turn over just fine, just wont start. If my buddies and i push it into the shade and let it sit for a while itll fire back up, no problem.
any suggestions as to what this could be?
thanks,
karl
thanks,
karl
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the_rail »</TD></TR><TR><TD CLASS="quote">so if i replace the main relay this will fix the problem? or will it keep happening with a replacement one?</TD></TR></TABLE>
guess you won't know until you do it.
i had the same problem! its your coil..you need to change the coil...
https://honda-tech.com/zerothread?id=895813 look..
i didnt kno what the hell it was until tahnks to EVERYONE who helped me out.. it worked but questiuon is did yours die out out of the blue on the freeway tho
I had that same problem, its the main relay. To get it out, you need to take the coin tray out (three phillips screws), then the main relay is attatched with one bolt (10 or 12mm) and a plug with 7 or so wires in it. Its a little tight in there, but you can get it out in a couple minutes.
I tried to fix mine before I bought a new one. I took the case off and re-soldered all the joints. You can tell which ones are bad because they have a little ridged ring around the solder. This worked for a couple weeks, but then started flaking out on me again. It was such a pain that I bought a new one and I've been trouble free ever since. Good luck.
nismogrendel
Apr 24, 2010 01:43 AM
bigwodeeb
Apr 5, 2007 09:41 AM
90jdmcrxdude
Aug 5, 2006 07:34 AM
