LS shifter and GSR shifter the same?
Old Jul 20, 2004 | 12:48 PM
jweezy225's Avatar
Default LS shifter and GSR shifter the same?
will the shifter from a GSR fit on my LS? cuz right now i have an SI shifter and it hits the exhaust and rattles
Old Jul 20, 2004 | 01:14 PM
95integraLS's Avatar
Default Re: LS shifter and GSR shifter the same? (jweezy225)
I wouldnt think they would be different...but im not sure.
Old Jul 20, 2004 | 01:36 PM
jweezy225's Avatar
Default Re: LS shifter and GSR shifter the same? (95integraLS)
alrite ill just try my luck, it should be better than what the SI shifter is doing now
Old Jul 20, 2004 | 02:12 PM
dave22's Avatar
Do you have a swap? You may need to get a linkage for your specific swap. My friend had a B16 CRX with the same problem and he got a linkage from HASport for like $250.
Old Jul 20, 2004 | 02:22 PM
MAV3RiCK478's Avatar
Default Re: (dave22)
94-01 shifters are the same all trim levels, dual bend
90-93 shifters are the same all trim levels, single bend
Old Jul 20, 2004 | 02:55 PM
skunk2eg's Avatar
Default Re: (MAV3RiCK478)
the gsr shifter is really good, when i got the ls swap done i got the gsr shifter and gsr linkage...
i would think the ls and gsr linkage are the same though
Old Jul 20, 2004 | 04:37 PM
jweezy225's Avatar
Default Re: (skunk2eg)
i have an LS with an LS motor, and LS linkage with a 99 civic SI shifter... **** feels loose and rattles like a bitch... also shifting kinda sucks... but better than the cut gsr shifter the old owner had in the car
Old Jul 28, 2004 | 08:31 PM
Integra_Nguyen's Avatar
Default Re: (jweezy225)
hey it's because you need a spacer on the bottom of your shifter where it connects to the linkage.
Old Jul 28, 2004 | 10:06 PM
dcb16's Avatar
Default Re: (Integra_Nguyen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra_Nguyen &raquo;</TD></TR><TR><TD CLASS="quote">hey it's because you need a spacer on the bottom of your shifter where it connects to the linkage.</TD></TR></TABLE>
this sounds like the problem to mee too
Old Jul 28, 2004 | 10:17 PM
TURBODC4TEG's Avatar
thats what i was thinking
Shaguar47
19
Jun 1, 2009 01:44 PM
DC206R
Jan 10, 2009 08:47 AM
SL0Wcrx
Aug 26, 2008 05:08 PM
jweezy225
Jul 29, 2004 10:26 PM
