LS Rods in D16Z6??
Old Jul 20, 2004 | 12:35 PM
Soccerking3000's Avatar
Default LS Rods in D16Z6??
Okay i currently run nitrous and was wondering how the LS rods fit in the d16, do i need to notch the block or anything? Also what hp can those rods handle, i plan on boosting my car and want a little more assurance that they will not break, looking to get around 220whp, will they hold. I also have ordered new arias pistons wit 9.1:1 compression, i would think that would be a good bottom end build???
Thanks in advance
matt
Old Jul 20, 2004 | 12:36 PM
Ricey McRicerton's Avatar
Default Re: LS Rods in D16Z6?? (Soccerking3000)
They aernt going to drop right in. By the time you've modded them to fit you could have just as easily gotten some aftermarket rods for your motor and been better off with less hassle and headaches.
My .02.
Old Jul 20, 2004 | 12:38 PM
Default Re: LS Rods in D16Z6?? (Ricey McRicerton)
ic its just i can get them for 20 bucks as opposed to 300 eagle h-beams, i am not going to run that large amout of boost, but i guess it would be easier to just put aftermarket ones in , are there any other oem rods that will drop into the d16 that are stronger???
Modified by Soccerking3000 at 9:19 PM 7/20/2004
Old Aug 2, 2004 | 07:05 PM
NLR808's Avatar
Not sure if ZC rods will fit for sure
Old Aug 2, 2004 | 07:33 PM
ABK's Avatar
ABK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">ic its just i can get them for 20 bucks as opposed to 300 eagle h-beams, i am not going to run that large amout of boost, but i guess it would be easier to just put aftermarket ones in , are there any other oem rods that will drop into the d16 that are stronger???
Modified by Soccerking3000 at 9:19 PM 7/20/2004</TD></TR></TABLE>
The amount the money you are going to spend at the machine shop trying to modify them, you might as well get aftermarket ones.
Old Oct 21, 2004 | 01:09 AM
Goullish's Avatar
Default Re: LS Rods in D16Z6?? (ABK)
Back from the Archives...
Several questions about the rods.
1.) Can anyone tell me if there is a difference in length between z6/y7 rods and LS rods. I haven't been able to get my hands on any to measure a distance.
2.) Can anyone tell me what EXACTLY would need to be modified to have these rods fit into A6 pistons. I mean exact, down to the ten thousandths of an inch (SolidEdge draft files would be prime)
Old Oct 21, 2004 | 03:21 PM
Goullish's Avatar
Default Re: LS Rods in D16Z6?? (Goullish)
Bump for my question.
Old Oct 21, 2004 | 03:26 PM
drewbie*'s Avatar
I say just find a good shot thats not going to rip you off. Its only a small amount of material they need to take off to make them work.
I would get them shot peened while you are at it.
IMO it would be well worth it.
Old Oct 21, 2004 | 03:27 PM
Gesundheit's Avatar
Default Re: LS Rods in D16Z6?? (Drew95eg)
you will have to nothc your block, shave the sides of the rods, and get a bushing for the wrist pin hole.
Old Oct 21, 2004 | 04:37 PM
Goullish's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drew95eg &raquo;</TD></TR><TR><TD CLASS="quote">I say just find a good shot thats not going to rip you off. Its only a small amount of material they need to take off to make them work.
I am the shop. I just want someone who has done the process before to lend some info, so I don't **** up some perfectly good pistons.
Old Oct 21, 2004 | 04:45 PM
mwieczorek43's Avatar
I remember seeing a step-by-step for this on Turbod16.com.
Wish i could tell you more, but thats a good place to look.
i wish i had my own machine shop
Old Oct 21, 2004 | 06:24 PM
Goullish's Avatar
Default Re: LS Rods in D16Z6?? (mwieczorek43)
Tried searching over there, their search engine isn't as finely tuned as one would hope for.
Thanks though.
Yeah, having the availablity of a any machine you could want is nice, we don't have much in the way of tooling though. Enough to suit my needs though, and the needs for the race kah.
Old Oct 21, 2004 | 06:26 PM
Corporation's Avatar
Economic Upturn, WUT
From: Alittle Placed Called None of Your Damn Business.
LS = B series ... d16 = civic = d series, won't work
Old Oct 21, 2004 | 06:38 PM
Goullish's Avatar
Default Re: LS Rods in D16Z6?? (Sweet Lou)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sweet Lou &raquo;</TD></TR><TR><TD CLASS="quote">LS = B series ... d16 = civic = d series, won't work</TD></TR></TABLE>
Um, yes it will, it just takes a little machining to get them to fit.
Old Oct 21, 2004 | 08:51 PM
heel_touge's Avatar
READ THE WHOLE FRIGGIN POST! this has been done many times. if you read the post its clear. take your uneductated trollin *** else where.
back on topic, have you tried speaking with anyone over at http://www.d-series.org or http://www.sohchonda.com ?
Old Oct 21, 2004 | 09:07 PM
blackcivic44's Avatar
Default Re: LS Rods in D16Z6?? (1slowcivic)
if you're going to spend that much on pistons... and the rods are really the d-series weakpoint... just spend a little more and be safer. sorry i can't be of more help
Old Oct 22, 2004 | 02:01 PM
drewbie*'s Avatar
Default Re: LS Rods in D16Z6?? (blackcivic44)
ill get the info if you can machine a set for me at a decent price... i was looking for a shop to do it.. i have the specs around here somewhere
Old Oct 22, 2004 | 02:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1slowcivic &raquo;</TD></TR><TR><TD CLASS="quote">
back on topic, have you tried speaking with anyone over at http://www.d-series.org or http://www.sohchonda.com ?</TD></TR></TABLE>
cool? it won't fit right in.
Old Oct 22, 2004 | 02:26 PM
drewbie*'s Avatar
D16
Bottom end width is .892" and the pin diameter is 19mm (.784")
B18
Bottom end width is .935" and the pin diameter is 21mm (.826")
So .0125" needs to be milled off each side of the bottom and the top end needs to be re-bushed to 19mm.
Old Oct 22, 2004 | 03:34 PM
Goullish's Avatar
cool? it won't fit right in.</TD></TR></TABLE>
You're right, ***, it won't. It requires some actual work.
Drew, Kickass numbers man.
Old Oct 22, 2004 | 04:52 PM
drewbie*'s Avatar
what would you charge me to machine a set if i mailed them out to you?
Old Oct 23, 2004 | 04:45 PM
.David's Avatar
bump so this goes in my recent topics list ;-)
Old Oct 30, 2004 | 02:35 PM
.David's Avatar
ok I have a question, what bearings would you use for this setup?
Old Nov 1, 2004 | 10:02 AM
rainmanef's Avatar
hmmmm.....(clearing throat) actually guys they do fit d series engines just not the 1.6. they fit the dx and other 1.5s because of the length of the ls rods.
for the dude with the original question....the most I've ever heard of stock ls rods handling is 14psi. BUT again that was HEARD of not seen. just get some after market rods and that will beef up the bottom end.
Old Nov 1, 2004 | 10:22 AM
Br1anPham's Avatar
ignorant
Save up for h-beams. Stock ls rods no fun. If rod velocity gets too high from high revs, it'd break anyway. Just use stock rods for now (they'll hold 220 hp).
Sure rods are only 30 bucks, unles syou have your own machine shops.. ehh, you'll be paying more then you want.
Ditto what Ricey said.
