Replacing the wheel studs from front hub.. what needs to be removed?
Old Jul 20, 2004 | 12:24 PM
typeeg's Avatar
Default Replacing the wheel studs from front hub.. what needs to be removed?
Whats up guys. I'm trying to replace the lug nut studs off my front wheels. I assume I will need to remove the hub to do this?
Some questions I had..
What size socket is needed to remove that big nut holding the hub in place?
Once I get that nut off will the hub simply come off or is there another step that much be done to get it off?
This is a 1991 civic si. Thanks guys.
Old Jul 20, 2004 | 01:23 PM
typeeg's Avatar
Default Re: Replacing the wheel studs from front hub.. what needs to be removed? (BrokenEF9)
help me out
Old Jul 20, 2004 | 01:54 PM
typeeg's Avatar
Old Jul 20, 2004 | 02:40 PM
typeeg's Avatar
how can no one know this?
Old Jul 20, 2004 | 03:43 PM
typeeg's Avatar
swaps require the removal of this nut I know that for sure.. so why is it that on a forum about swaps doesn't know this??
Old Jul 20, 2004 | 03:57 PM
hondaguyef's Avatar
remove the axle nut and then use aslide hammer to remove the hub. It is very simple.
tutorial: https://honda-tech.com/zerothread?id=907985
I thought I just answered this quetsion?????
Old Jul 20, 2004 | 04:41 PM
krazie1's Avatar
BANNED
Default Re: Replacing the wheel studs from front hub.. what needs to be removed? (hondaguyef)
to do the studs of the hub u don't need to remove the hub
just kinda of think a bit
I did three without the use of such tool and removing the hub
I just sort of knocked them back without the shield for the brake rotor
and hammered the new ones in
u got to tilt a bit and once they are in u just straighten them out and one good wack and they are in
Old Jul 20, 2004 | 05:09 PM
XrcR6's Avatar
Default Re: Replacing the wheel studs from front hub.. what needs to be removed? (krazie1)
Sometimes it depends on the Honda model, on some you can remove the studs by hammering them through and a little wiggle-ing past the hub carrier; others you need to get the hub off because there is just not enough room. And if you are replacing them with extended studs and it was tight getting the stock ones out, you'll definitely need to pull the hub regardless.
I did it on a '91 CRX Si, should be the same as yours, and had to press the hub out. The axel nut is 32mm. You also need to remove the rotor, which means you need to move the caliper out of the way too. Then, you need a hydraulic press to get the hub out. Some people use a baby-sledge, but you run the risk of damaging something. Removal of the hub by either method usually destroys the wheel bearing, so you'll need to be prepared to replace that.
Old Jul 20, 2004 | 05:21 PM
typeeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazie1 &raquo;</TD></TR><TR><TD CLASS="quote">to do the studs of the hub u don't need to remove the hub
u got to tilt a bit and once they are in u just straighten them out and one good wack and they are in </TD></TR></TABLE>
see I've read about this but I don't see how you can fit the stud through the hole because of head on the stud being too wide... I know you can kind of tilt it in but if you do this then you might mess up the threads on the new stud since you are kinda rubbing the threads against the inner holes of the hub correct? Maybe I can think of a way to protect the threads while fitting it in but by all means if I can do it without removing the hub I would go that route!
airikkCRX
Jan 16, 2010 04:31 PM
ewoo
Feb 24, 2009 04:23 PM
simonEp3
Sep 3, 2008 04:49 PM
NeWsCr
Dec 13, 2006 06:43 AM
typeeg
Jul 20, 2004 04:47 PM
