PLEASE HELP!!! Any one know how to put together ls-vtec?
Sorry guys I'm a noob. I'm new at honda sit. I have a b18b block and a b18c head. What do I need to put it together? What parts do I need? Where can I get these parts? What head gasket should I use? What can I do for the return oil? What about the pins and what size do I need? Where do they go? Were can I put the sensor? Do you guys think I'm missing any other question? Is there any threads or/and pics I can use for reference? PLEASE HELP ME OUT!!!
I owe a BIG THANKS to the honda-tech board member for this!!!!
ok here goes..
parts you need
LS/vtec oil line kit (buy at kit its easier than explaining all the parts)
b18b headgasket will be fine
dowels, either buy the golden eagle ls/vtec dowels, or have a machine shop do this. On the head there are 2 dowels, move them to the other side.....(intake side, if i remember correctlly)
they also have to plug an oil port on the bottom of the head(someone post a pic please) and tap a main plug on the back of the head for the oil line.(pics are needed on these 2)
return oil? no your getting terms mixed up, unless your going turbo.
put the sensor? what sensor? knock? oil pressure? with the kits i suggested for the LS/vtec oil line kit, using the stock oil pressure sensor shouldnt be a problem, and i would recommend you use the stock oil pressure sensor, and hooking it up.
pins? dowels? i explained the dowels above
computer, you need a computer preferably a vtec one. and do you have an engine harness that has vtec already wired in? if so good, if not then it needs to be wired.
now all the all motor gurus out there need to proof read this too, make sure i didnt miss anything.
good luck too
Modified by pornstarSR at 9:20 PM 7/20/2004
parts you need
good luck too
brandonb18
Oct 18, 2009 05:11 PM
cracker1252
Mar 31, 2009 06:24 PM
jksmith
Aug 25, 2008 02:40 PM
Stroker
May 22, 2003 11:24 AM
