RIM/TIRE SIZE????hELP
Old Jul 20, 2004 | 11:44 AM
spicoli's Avatar
Default RIM/TIRE SIZE????hELP
I WANT TO GET SOME RIMS FOR A 94 SI COUPE,(CIVIC) BUT I WAS TOLD IF THE OVERALL SIZE WAS LARGER THAN STOCK, IT WOULD **** MY SPEED SENSOR??
OR SOMETHING LIKE THAT
dOES IT MAKE A DIFFERENCE IF I PUT 17'S WHERE THE STOCK 14'S WERE? wHAT PROBLEMS CAN THIS CAUSE
Old Jul 20, 2004 | 11:47 AM
Sijray21's Avatar
Default Re: RIM/TIRE SIZE????hELP (spicoli)
first off, turn off the caps lock.....
you adjust the tire sizes with the rim sizes
Click Here to solve all your problems
Old Jul 20, 2004 | 11:49 AM
Nova_Dust's Avatar
You got larger wheel, your overall circumference increases. For every tire rotation, you are travelling longer distance. I am running 195/60/14" compare to stock 185/65/14" so it will take my tire to make more revolution to cover the same distance.
Old Jul 20, 2004 | 04:34 PM
SiRP's Avatar
Your speed sensor would most likely reflect an inaccurate speed if you change your overall diameter (rim+tire). Other than that, if the diameter and weight difference aren't too significant, i don't see you breaking anything.
Old Jul 20, 2004 | 05:57 PM
crashN2u's Avatar
Default Re: RIM/TIRE SIZE????hELP (SiRP)
I was told by a shop that if you go bigger than your overall stock wheel and tire height that you will lose your cruise control. I'm talking about plus sizing. Lowering the height of your sidewall for every inch you add to the rim. Can someone confirm this about Honda's. I know for a fact it happens with benz's.
Old Jul 20, 2004 | 06:22 PM
94CoupeEJ1's Avatar
Default Re: RIM/TIRE SIZE????hELP (crashN2u)
The car doesn't know what size wheels and tires you are putting on it. I have a 94 EX and some idiot at a tire shop here in town tried to tell me because it had an electronic speedometer that it would adjust for whatever size wheel and tire I put on. All it does is count revolutions so if you increase the overall size it is going to read that you are going slower than you actually are. Actually it is problably off from the factory so much that you might get it accurate by putting on 2-3 sizes too big. I have 195-60-14's and it is still reading 2-3 mph fast at 65. 205-50-15's is what I plan to go to but that is even smaller than the 195's in diameter so even with an oversize tire my speedo will be reading too fast.
Old Jul 20, 2004 | 08:19 PM
Nova_Dust's Avatar
Maybe that's why a lot of people got speeding tickets with their 17 or 18 inch rims...
Costco
Mar 28, 2011 10:15 AM
j0keefe21
10
Jan 16, 2009 07:00 PM
supra360
Nov 10, 2008 06:24 PM
drktorn
Dec 20, 2005 05:50 PM
dclub01
May 24, 2003 07:45 PM
