exhaust compatibility question
Old Jul 20, 2004 | 11:08 AM
shhh151's Avatar
Default exhaust compatibility question
hey guys my cousin has a 01 gsr and is getting rid of his skunk2 exhaust, will it fit on my 95 gsr?
Old Jul 20, 2004 | 11:10 AM
IntegraBoy04's Avatar
Default Re: exhaust compatibility question (GSR515)
I think you have to modify it a little bit.
Old Jul 20, 2004 | 11:26 AM
purplegsr's Avatar
Default Re: exhaust compatibility question (IntegraBoy04)
You will have to modify the piping and reweld it, or if you have access to a 00 or 01 header and cat, it will bolt up fine to your 95. I believe the cat and header are longer on the 00/01, so the piping would need a little bit added to it.
Old Jul 20, 2004 | 12:10 PM
shhh151's Avatar
thanks for the info
Old Jul 21, 2004 | 02:13 PM
tweekerz's Avatar
Default Re: exhaust compatibility question (purplegsr)
Hypothetically speaking if he were to replace his stock '95 header/cat with a aftermarket header/cat made for 98-01 he could do it all at the same time and it would fit. Would there be any issues with this?
Modified by GoodTimes at 3:27 PM 7/21/2004
Old Jul 21, 2004 | 04:04 PM
purplegsr's Avatar
Default Re: exhaust compatibility question (GoodTimes)
yes, you are correct, as long as the cat was the same length as the stock 98-01 cat.
Old Jul 22, 2004 | 01:31 PM
dwolsten's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoodTimes &raquo;</TD></TR><TR><TD CLASS="quote">Hypothetically speaking if he were to replace his stock '95 header/cat with a aftermarket header/cat made for 98-01 he could do it all at the same time and it would fit. Would there be any issues with this?</TD></TR></TABLE>
Yep. The 00/01 GSR cat is longer than the 94-99 GSR one. You should be able to put the 00/01 GSR cat on your 95 GSR, and then use the Skunk2 exhaust (I have this exact same model on my 94 LS BTW). The only big issue I can see is that you'll have to plug the O2 sensor hole: the later cat has two O2 sensors, one before the cat and one after. Since your car only uses the sensor before the cat, you'll have to find a way to plug the other hole. You should be able to get a short bolt that'll fit there.
Grimmage
May 9, 2011 09:39 PM
MJsEFhatch
Oct 7, 2009 11:14 AM
EFstyle
Jun 18, 2006 05:21 PM
13HYBRID20
Apr 17, 2005 09:40 AM
mkiv98
Jan 21, 2005 01:51 PM
