Tial Wastegates - BOV's In Stock!!!!!
In Stock!!!!! FREE SHIPPING!!!!!!!!!!!!!!
Wastegate 38mm .4 Bar Silver $210.00
Wastegate 38mm .6 Bar Silver $210.00
Wastegate 38mm .4 Bar Blue $227.00 SOLD
Wastegate 46mm .7 Bar Silver $456.00
Blow Off Valve 9psi Silver Aluminum Flange/Mild Steel $205.00
Blow Off Valve 9psi Blue Mild Steel Flange/Aluminum $210.00 SOld
Blow Off Valve 9psi Red Mild Steel Flange/Aluminum $210.00 SOLD
Wastegate 44mm .7 Bar Silver $347.00
Wastegate 44mm .7 Bar Blue $367.00 Sold
Thank you,
Modified by Marty T at 10:45 PM 6/3/2005
Modified by Marty T at 10:46 PM 6/3/2005
Thank you,
Each spring is good to whatever psi you can give it. The spring only affects how it opens and closes during shifts. The less psi spring the longer the valve will stay open and vice versa.
I need a .6 bar 38mm in silver... Can I use a credit card??? I need it by Friday to get my car back up and running and tuned... IM me and let me know ASAP please...
-Chris
-Chris
Chris,
you can use your credit card give me a buzz.
The 38mm does not come with a flange for the dump-tube.
